New Windshield for sale AND OTHER PARTS!
I have a brand new windshield for a N600 sedan this is the real thing .
If anyone is interested make me an offer over $100.00
There is a little lamination seperation about 1/2 " around the lower two
corners but I think the rubber will cover it up other than that it is
NEW! no scratches at all, never been installed.
I also have a Z600 rear window that I took out of a car that was in good
shape.
I also have a carb for a N600
i also have two starters they may need rebuilt I dont know.
I also have a set of cylinders in good condition.
I also have most all the rubber boots for around the engine in great
condition.
I also have a set of rims and hub caps for n600 in great shape like new.
I will look and see what else i HAVE.
shape.
condition.
James Hawkins
Re: New Windshield for sale AND OTHER PARTS!
I could use one as I busted mine but the rubber is so hard I don't know if it would be reusable. Can new rubber be had?
> Dan K
> Sunday, May 10, 2009 8:10 PM
> [2cylinderhondas] New Windshield
> I have a brand new windshield for a N600 sedan this is the real thing > .
> There is
> a little lamination seperation about 1/2 " around the lower two > corners but > I think the rubber will cover it up other than that it is > NEW! no scratches > at all, never been installed.
> shape.
> N600
> know.
> I also
> great
> condition.
> HAVE.
> Checked by AVG -
> www.avg.com
> Version: 8.5.325 / Virus Database: 270.12.24/2107 - Release > Date: 05/10/09 07:02:00
Cotten,
I thought you had a Z600 coupe? The windshield for sale is for an N600 sedan. Do you need the rubber gasket for an N600 sedan windshield or for the Z600 windshield?
See Yours in Just 2 Easy Steps!
The Average US Credit Score is 692.> I could use one as
> I busted mine but the rubber is so hard I don't know if it would be > reusable. Can new rubber be had?
> > Dan K
> > PM
> > I have a brand new windshield for a N600 sedan this is the real thing > > .
> > There
> > is a little lamination seperation about 1/2 " around the lower > > two > > corners but I think the rubber will cover it up other than that it > > is > > NEW! no scratches at all, never been > > installed.
Kevin Gailey
I have a windshield too if you need one, not new though.
Kevin Gailey From:
James Hawkins To:
Sunday, May 10, 2009 7:16:58 PM Subject:
Re: [2cylinderhondas] New Windshield for sale AND OTHER PARTS!
Kevin Gailey From:
James Hawkins To:
> Dan K
> There is
> shape.
> N600
> know.
> I also
> great
> condition.
> HAVE.
> Checked by AVG -
> www.avg.com
James Hawkins
Dale,
No, it's a 71 Sedan.
I can make do with my windshield but not look so good.
The blow from the hood was down in the drivers bottom corner where the inspection sticker goes. The runs from it are down low so they don't bother with my vision.
> goinhm@...
> Sunday, May 10, 2009 10:12 PM
> Cotten,
> for sale is for an N600 sedan. Do you need the rubber gasket for > an N600 sedan windshield or for the Z600 windshield?
> > I could use one
> > as I busted mine but the rubber is so hard I don't know if it would be > > reusable. Can new rubber be had?
> > > Dan K
> > > Sent:
> > > PM
> > > I have a brand new windshield for a N600 sedan this is the real > > > thing .
> > > $100.00
> > > There is a little lamination seperation about 1/2 " around > > > the lower two > > > corners but I think the rubber will cover it up other > > > than that it is > > > NEW! no scratches at all, never been > > > installed.
> See
> Checked by AVG -
> www.avg.com
Mike could tell you were to get the rubber to make one
> > Dan K
> > There is a little lamination seperation about 1/2 " around the lower two > > corners but I think the rubber will cover it up other than that it is > > NEW! no scratches at all, never been installed.
> > I also have a Z600 rear window that I took out of a car that was in > > good > > shape.
> > I also have most all the rubber boots for around the engine in great > > condition.
> > Checked by AVG - www.avg.com
> > Version: 8.5.325 / Virus Database: 270.12.24/2107 - Release Date: 05/10/09 07:02:00
James Hawkins
OK Thanks good to know. Will check into it soon.
> Dan Kent
> Monday, May 11, 2009 5:48 PM
> James
> Hawkins cotteni@brazosnet. com
> > I
> > could use one as I busted mine but the rubber is so hard I don't know if it > > would be reusable. Can new rubber be had?
> > > Dan K
> > > Sent:
> > > Sunday, Ma y 10, 2009 8:10
> > > PM
> > > $100.00
> > > I also have a Z600 rear window that I took out of a car > > > that was in good > > > shape.
> > > i
> > > I also
> > > condition.
> > > I also
> > > I
> > > Checked by AVG
> > > - www.avg.com
> Checked by AVG -
> www.avg.com
> Version: 8.5.325 / Virus Database: 270.12.24/2108 - Release > Date: 05/11/09 05:52:00
w/s rubber
Colford sells a repro rubber seal for 600's. Easy to install with a 3/16" nylon cord (rope).
> From: Dan K
> Sent: Sunday, May 10, 2009 8:10 PM
> Subject: [2cylinderhondas] New Windshield for sale AND OTHER PARTS!
> shape.
> condition.
James Hawkins
Kevin, how much would the windshield run, shipped and insured??
I'm in North central Texas 76481????????????
Is it in good shape?
> Kevin
> Gailey
> Sunday, May 10, 2009 10:16 PM
> I
> Kevin Gailey
> James Hawkins cotteni@brazosnet. com
> I
> could use one as I busted mine but the rubber is so hard I don't know if it > would be reusable. Can new rubber be had?
> > Dan K
> > 2cylinderhondas@
> > yahoogroups. com
> > There
> > is a little lamination seperation about 1/2 " around the lower > > two > > corners but I think the rubber will cover it up other than that it > > is > > NEW! no scratches at all, never been installed.
> > I also have a
> > i also have two
> > condition.
> > I will look and
> > Checked by AVG -
> > www.avg.com
> > Version: 8.5.325
> > / Virus Database: 270.12.24/2107 - Release Date: 05/10/09 > > 07:02:00
> Checked by AVG -
> www.avg.com
Kevin Gailey
Which windshield do you need? Mine is for a Z600 From:
James Hawkins To:
Saturday, May 16, 2009 4:55:47 PM Subject:
I'm in North central Texas 76481??????? ?????
James Hawkins To:
> Kevin
> Gailey
> I
> Kevin Gailey
> I
> > Dan K
> > 2cylinderhondas@
> > yahoogroups. com
> > There
> > I also have a
> > i also have two
> > condition.
> > I will look and
> > Checked by AVG -
> > www.avg.com
> > Version: 8.5.325
> Checked by AVG -
> www.avg.com
