I talked to Jeff yesterday (actually emailed and he called me). he
mentioned that the 600 booster is 399.00 to rebuild depending on
condition. the masters are 85-95 dollars unless they need stainless
steel sleeving which would be more. .Karp's Booster at
XXX-XXX-XXXX.....Ask for Jeff...
Booster rebuild cost
Re: Booster rebuild cost
Tell Jeff, if he is going to sleeve an aluminum casting he has to use brass otherwise stainless will crack the casting.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > enerdome > Sent:
> Wednesday, January 21, 2009 12:05
> [2cylinderhondas] Booster rebuild cost
> he
> mentioned that the 600 booster is 399.00 to rebuild depending > on > condition. the masters are 85-95 dollars unless they need > stainless > steel sleeving which would be more. .Karp's Booster > at > XXX-XXX-XXXX. ....Ask for Jeff...
