My 73 Sedan
davepdouglass
My 73 Sedan
Post by davepdouglass »
Hi gang. I have decided to sell my 73 sedan. It is in pieces and
partially restored. I have had this car for 23 years. I got it when
I was 15 yrs old from my cousin who was a yamaha mechanic. I drove
it all thru highschool and then a few years until I went to CA. When
I got back to NH in 1995 I got it running and drove it while then
decided to restore it. It has either 45 or 65k miles on it original.
The body is on a home made rottisorie (included with the car)you can
spin it 360*. When I tore it down I discovered the previous owner
before my cousin had mangled the roof at the windshiled and the roof
was all torn up so I grafted in a good piece from a donor car from a
pillar to b pillar. It needs to be finish welded. It needs rocker
work a little floor brace work and some varous other areas. I also
grafted in a pretty good rear trunk form the other car but it isnt
done. It needs body work, cut fab weld repair etc. The doors and
hood are in pretty good shape. Its been indoors since 1989 except a
few months in 1995. Engine is rebuilt with new piston rings seals
etc. I tore down the engine had it tanked, had the cylinders honed
to accept the new rings. I painted the engine in pieces with high
temp aluminum and baked the peices to cure them. It has a nos
tensioner and guide and chain. It is on an engine stand on a cradle
I made to work on it (cradle included, engine stand not. Blasted and
painted parts, painted with PPG DP epoxy primer with flat black paint
are, gas tank tank welded up and painted the bottom, fornt frame,
struts with silver springs, suspention componants, rear springs etc.
the front frame has a cradle to suport it with casters, included.
I rebuilt the dash with one where the radio was not cut out and the
pad was in better shape. I have a parts car with most of the engine
etc. I have 4 blasted rims painted with ppg silver and a set of 4
brand new tires form tirerack. two sets of rear brakes, I swapped the
backing plates to use the nos two piston brake cylinders. I have
many extra parts, heads, cylinder barrels not to mention seats and
the parts car. Tons of rims etc. If i dont have double of most
things you need I'd be surprised.
Anyone interested the car is in Rye NH couple miles from I95. I cant
ship it but i will help you load it etc and answer all your
questions. I have the chiltons manual and the blue bible. I'd like
$2000.00 for everything.
ddouglass@... or XXX-XXX-XXXX
Dave
