I Just Purchased A 1972 Honda 600 Sedan That's Almost Done Being
Restored,I'm Looking For A Fuel Tank,The One That's In It Isn't Leaking
But My Fuel Supply Is Blocked Off By A Plugged/Rotted Supply Pipe
Inside The Tank,I Figured Before I Cut The Tank Open To Repair it I
Would Check If Anyone Has One?
Fuel Tank
jeffanson2005
Re: Fuel Tank
Hi! I had a similar problem recently with a restoration project where
the fuel was just dripping into the fuel pump from the tank. I was
able to remedy it by using compressed air from fuel line back into tank.
It took a while, but it worked for me and the flow has been fine ever
since. Hope this helps!
Jeff
Miami
72 Z600
Jeff
Miami
72 Z600
Re: Fuel Tank
I get plugged tanks too. I have had really good success with a cordless
drill and a short section of speedometer cable. I roto rooter the tube
up into the tank.
up into the tank.
Leaking
