My '71 sedan (that I autocross) has some whimpy brakes. I've rebuilt
the rear cylinders (the single slave cylinder type; not the dual,
btw.), done a couple of brake bleeds including the booster, added new
pads and shoes, and replaced the hoses.
Can you guys (and gals) lock up your tires when doing a panic stop in
a straight line? If so, how old and what type are your tires? I can't
lock the tires up, and I run A-008's (sticky tires) or goodyear slicks
(really sticky tires).
When I am doing a panic stop, I feel like the pedal is initially firm,
and then about 1/2 way into the pedal stroke, it turns mushy... you
can keep pressing harder, but you're not going to stop any faster.
Does anyboy else have this problem? More importantly, has anybody else
solved this problem?
Thanks, Miles E.
while we're talking about brakes...
Re: while we're talking about brakes...
Hi Miles;
Look at the rear brake line, I believe it is weak and balooning on you. I
know you said you replaced the hoses, but I had brand new hoses fail.
Brilliant! in all my pondering, I had forgotten about the REAR brake
line! Thanks.
-Miles E.
line! Thanks.
-Miles E.
I am selling my 1971 Honda N600. If anyone is interested let me know and I will give you further details.
jalos76@...
wanna600 wrote:
jalos76@...
wanna600 wrote:
Yahoo! FareChase - Search multiple travel sites in one click.> Brilliant! in all my pondering, I had forgotten about the REAR brake > line! Thanks.
> -Miles E.
> --- In 2cylinderhondas@yahoogroups.com, "Bill Colford"
> > Hi Miles;
> > Look at the rear brake line, I believe it is weak and balooning on > you. I > > know you said you replaced the hoses, but I had brand new hoses fail.
> > From: 2cylinderhondas@yahoogroups.com
> > [mailto:2cylinderhondas@yahoogroups.com]On Behalf Of wanna600 > > Sent: Monday, October 24, 2005 8:26 PM > > To: 2cylinderhondas@yahoogroups.com > > Subject: [2cylinderhondas] while we're talking about brakes...
> > My '71 sedan (that I autocross) has some whimpy brakes. I've rebuilt > > the rear cylinders (the > single slave cylinder type; not the dual, > > btw.), done a couple of brake bleeds including the booster, added new > > pads and shoes, and replaced the hoses.
> > Can you guys (and gals) lock up your tires when doing a panic stop in > > a straight line? If so, how old and what type are your tires? I can't > > lock the tires up, and I run A-008's (sticky tires) or goodyear slicks > > (really sticky tires).
> > When I am doing a panic stop, I feel like the pedal is initially firm, > > and then about 1/2 way into the pedal stroke, it turns mushy... you > > can keep pressing harder, but you're not going to stop any faster.
> > Does anyboy else have this problem? More importantly, has anybody else > > solved this problem?
> > Thanks, Miles E.
