I can help with the correct way to wire your coil, I have one on my N600 Sedan now.
XXX-XXX-XXXX
mike
Re: Digest Number 1012
dustyspath
I'd like to help as well.
Are there any thick black rubber wires coming out of the coil? They are extra cost to the mfr so they are used for the HIGH VOLTAGE: one goes to one spark plug, the other fits the other plug. Then the coil should have one terminal that goes to the distributor(points) and the case should be grounded.
I put a motorcycle coil in my 600 car long ago, but it ate spark plugs because it was much higher voltage than the coil I replaced, yet it ran well. Good luck!
Let us know your progress.
Marshall tmoc1990@...
> XXX-XXX-XXXX
> mike
> From: 2cylinderhondas@yahoogroups.com
> Sent: 4 Sep 2005 12:10:44 -0000
> Subject: [2cylinderhondas] Digest Number 1012
> ------------------------ Yahoo! Groups Sponsor --------------------~--> > Get fast access to your favorite Yahoo! Groups. Make > Yahoo! your home page > http://us.click.yahoo.com/dpRU5A/wUILAA ... /fnTolB/TM > ">Click > Here! > --------------------------------------------------------------------~->
> There are 2 messages in this issue.
> Topics in this digest:
> 1. Car for sale or free?
> From: "Miles Chappell" 600miles@...
> 2. dumb question re:coil wiring
> From: "jmistche" rokhound@...
> Message: 1
> Date: Sat, 03 Sep 2005 20:05:28 -0000
> Subject: Car for sale or free?
> It's not mine and he's probably not in group, so don't ask me or > reply to group.
> Thanks - Miles
> From: Steve Calise
> 600miles@...
> Sent: Saturday, September 03, 2005 7:20 AM
> Subject: Contact From 600miles.com
> Email:
> calise05@...
> Message: I have a 71 n600 and it,s needs restoring but I,m not > intere I,m in interested in doing it so I,d give it to any one that > wants it. It,s in Massachusett I don.t want to junk it. It,s all > there plus extra parts Maybe you know some one. THANKS Steve
> Message: 2
> Date: Sat, 03 Sep 2005 23:40:06 -0000
> Subject: dumb question re:coil wiring
> I am installing a new Accel 140403S coil in my 600 sedan and I don't > know how to connect the wires from the points and from the wiring > loom. There are two threaded posts on the coil and neither are > labelled; are these both connected to the low voltage side of the > coil? If so, does it matter which one I connect to the +12VDC and > which one goes to the points? The coil is intended for motorcycles > and the instructions esentially say "hook it up like your old one".
> TIA,
> Jon Mistchenko
