Re: Digest Number 963
tmoc1990
Post by tmoc1990 »
I have had  prints made of the upper chain guide roller, in the past new parts have been made using a material called delrin,l but there has been a heat issue and early ones have melted from the heat generated by the powerful 600cc engine.  The material must be able to withstand temperatures in excess of 500 degrees in order for the part to last, I'm not sure what the cart wheels are made of but you must be careful because what every wears off falls into the bottom of the motor and can find its way into the oil pump and that is another problem on the horizon.
jpro8071
Post by jpro8071 »
I know that a chain with slack can eat into the engine case - I've
seen one or two with some minor case wear (which probably means
aluminum in the pan - also bad.)
Anyone seen a motor go completely because of the lack of a good upper
chain guide roller? I would think that a good tensioner (which some
folks like Tim rebuild/recondition) would be far more important than
this guide.
>horizon.
F650CSA
Post by F650CSA »
I'm not sure about the heat and oil combination, or their chemical makeup, but years ago we used to repair shopping carts. Those damn wheels were everywhere, we tried everything to get rid of them and you couldn't hardly burn them either. The rubber just wouldn't catch. That's what made me think of them 1st.
jpro8071 wrote:
> I know that a chain with slack can eat into the engine case - I've > seen one or two with some minor case wear (which probably means > aluminum in the pan - also bad.) > Anyone seen a motor go completely because of the lack of a good upper > chain guide roller?  I would think that a good tensioner (which some > folks like Tim rebuild/recondition) would be far more important than > this guide.
> --- In 2cylinderhondas@yahoogroups.com, tmoc1990@a... wrote:
> >  I have had  prints made of the upper chain guide roller, in the past > >new parts have been made using a material called delrin,l but there has > >been a heat issue and early ones have melted from the heat generated by > >the powerful 600cc engine.  The material must be able to withstand > >temperatures in excess of 500 degrees in order for the part to > last, > >I'm not sure what the cart wheels are made of but you must be careful > >because what every wears off falls into the bottom of the motor and can > >find its way into the oil pump and that is another problem on the > >horizon.
Do You Yahoo!?
Post by Steve »
The Delrin rollers melt for sure, I have pictures of one with a
nickel sized hole in the center. If the slipper falls down into the
engine the chain will slice into the front of cylinders and
eventually oil will leak out. The top of the cylinders should get
TIG welded and then you can chisel out a new pin groove or have
someone mill the groove for you. I once found a cylinder that had
the slipper Bondoed into place, I had a really hard time removing it.
Post by Lyle »
Yea know Miles;
I use JB weld to keep all slipper pins in place. And, removing the pin
later was not all that hard. It's an extra step, but keeps that bit of
aluminum a loose pin grinds away, from working its way into the bearings.
Another area that causes a lot of problems and is almost never corrected is
the primary and secondary transmission shaft bearing keepers. Both on the
small and large bearings. The large bearing keepers on the clutch side
always seem to wear. However the other large bearing keeper doesn't. I
find that replacing them helps to keep the thrust washer and oil pump rod
from premature wear.
James
Post by James »
I have two upper chain guide rollers (new Old Stock) available for
sale. Please e-mail me if you require photos and prices including
shipping. kiwi_aircooled_honda_fan@...
James
James
Post by James »
Both Cam Chain Rollers have found a buyer in Vermont. Thanks. Sorry
for not calling people on the 'phone; I'm in New Zealand and the call
would be $$$$
James
, jeff segur wrote:
> Hey James. How much for both and shipping to zip 43413?
> James wrote:I have two upper chain guide rollers (new
> shipping. kiwi_aircooled_honda_fan@h...
> James
, "Bill Colford"
> > Yea know Miles;
removing the pin
bit of
> bearings.
> corrected is
> on the
side
doesn't. I
> pump rod
> > [mailto:
]On Behalf Of Miles Chappell
> > Sent: Sunday, June 12, 2005 10:49 PM
> > Subject: [2cylinderhondas] Re: Digest Number 963
> > Miles
, "jpro8071"
> > upper
> > some
> > than
> > > this guide.
> > past
> > there has
> > generated by
> > withstand
> > last,
> > careful
> > and can
> > > >horizon.
