SPRING CLEANING
CARS AND PARTS FOR SALE
TUNE UP KIT N600 OR Z600 $40.00
NOS OIL FILTERS $9.00
NOS FUEL FILTERS $4.00
1967 HONDA LN360 VAN $2,000
1977 HONDA TN360 TRUCK $2,000
1967 HONDA S800 COUPE CHAIN DRIVE $2,500.00
1967 HONDA S800 COUPE RESTORED AND READY TO ENJOY $18,000.00
1979 HONDA CIVIC CVCC HONDAMATIC LOTS OF NEW PARTS $2,500.00
NEW N600 HAWAIINA ENGINE, TWO MILES, STAINLESS STEEL EXHAUST, HIGH LIFT CAM, NOS CRANKSHAFT, AND MORE. THIS ONE IS THE REAL DEAL!!!!!!!!!!!!!!!!!!!!!
ALL ITEMS LOCATED IN NORTH CAROLINA
XXX-XXX-XXXX
VISA-MASTERCARD-AMEX ACCEPTED
Re: Digest Number 893
Hello
Is there any chance of seeing a photo of the LN360 and
the TN360?
Regards
Peter Shaw
--- tmoc1990@... wrote:
Find local movie times and trailers on Yahoo! Movies.
http://au.movies.yahoo.com
the TN360?
Regards
Peter Shaw
------------------------------------------------------------------------> SPRING CLEANING
> $18,000.00
> $2,500.00
> XXX-XXX-XXXX
> Sent: 10 Mar 2005 16:42:09 -0000
> Subject: [2cylinderhondas] Digest Number 893
> There are 2 messages in this issue.
> Topics in this digest:
> 1. Car won't turn over-How to bench test
> starter?
> From: " " 2. RE: Car won't turn over-How to bench test
> starter?
> From: "william colford"
> Message: 1
> Date: Thu, 10 Mar 2005 05:39:20 -0000
> From: " " Subject: Car won't turn over-How to bench test
> starter?
> Now my car won't turn over. I hear a click noise as
> i turn the key but
> not quite sure if its coming from the starter since
> I'm sitting in the
> drivers seat. The car was starting and running just
> yesterday. havne't
> changed anything since. I even charged the battery
> and tried to start
> with the charger in "boost" mode. I suspect the
> starter or faulty
> electrical connections. The starter has probably
> been replaced before.
> It has markings on it in yellow, you know the same
> yellow paint color
> that salvage yards use to mark their parts.
> After looking around i found the terminals on the
> starter quite rusty.
> I'm thinking of pulling it and cleaning it but what
> is a good method
> of testing the starter off the car?
> Also, I found a wire disconnected. It is located on
> the passenger side
> below the coil and leads into the engine case. Are
> these wires for
> the generator? I have a service manual with full
> wiring diagram but
> can't quite identify the wires. There are 3 or 4 of
> them, mostly
> white and one that is white with black stripe. Also
> the connector
> that is on the harness side of the voltage regulator
> looks pretty beat
> up. It has some bare wire showing that is corroded
> green. Ugghh,
> electrical problems are such a pain. Its always hard
> to know where to
> start.
> Message: 2
> Date: Wed, 9 Mar 2005 22:51:15 -0800
> From: "william colford" Subject: RE: Car won't turn over-How to bench test
> starter?
> Oh No, Not the ugly green crud stuff... If it was
> running yesterday I would
> check the battery cables. The wires to the
> connectors may be corroded in
> side and causing a bad connection. And, if you push
> it in second will it
> start?
> Sent: Wednesday, March 09, 2005 9:39 PM
> Subject: [2cylinderhondas] Car won't turn over-How
> to bench test
> starter?
> i turn the key but
> I'm sitting in the
> yesterday. havne't
> and tried to start
> starter or faulty
> yellow paint color
> is a good method
> the passenger side
> these wires for
> wiring diagram but
> them, mostly
> the connector
> looks pretty beat
> green. Ugghh,
> to know where to
> start.
You can go to Mike's web site - www.honda600shop.com - and look under cars for sale.
To see more pictures of the TN360, take a look here...
Specs and pictures of the cool little Honda TN360 truck
How much for the hawaiin engine?
On Thu, 10 Mar 2005 12:13:42 -0500,
tmoc1990@...
> SPRING CLEANING
> XXX-XXX-XXXX
------------------------ Yahoo! Groups Sponsor --------------------~-->
Help save the life of a child. Support St. Jude
Children's Research Hospital's
'Thanks & Giving.'
HREF="
http://us.click.yahoo.com/6iY7fA/5WnJAA ... /fnTolB/TM"
>Click
Here!
1. Car won't
> turn over-How to bench test starter?
From: " " RE: Car won't turn over-How to bench test starter?
> 1
> starter?
Now my car won't turn over. I hear a click noise as i turn the
> key but
not quite sure if its coming from the starter since I'm sitting in
> the
drivers seat. The car was starting and running just yesterday.
> havne't
changed anything since. I even charged the battery and tried to
> start
with the charger in "boost" mode. I suspect the starter or
> faulty
electrical connections. The starter has probably been replaced
> before.
It has markings on it in yellow, you know the same yellow paint
> color
> found the terminals on the starter quite rusty.
> and cleaning it but what is a good method
> car?
Also, I found a wire disconnected. It is located on the passenger
> side
below the coil and leads into the engine case. Are these wires for
the
> generator? I have a service manual with full wiring diagram but
can't quite
> identify the wires. There are 3 or 4 of them, mostly
> white with black stripe. Also the connector
> the voltage regulator looks pretty beat
> that is corroded green. Ugghh,
> always hard to know where to
start.
Message:
> 2
> starter?
Oh No, Not the ugly green crud stuff... If it was running
> yesterday I would
check the battery cables. The wires to the connectors may
> be corroded in
side and causing a bad connection. And, if you push it in
> second will it
start?
