sedan brake help
Jefrey
sedan brake help
Post by Jefrey »
Hello!
I have a just short of fully restored sedan that i recently got
going again.It runs and looks great but the front brakes don't
release enough after stopping or slowing down. The only way to get
them to release fully is to jab at the brake pedal hard. This seems to
free them up enough to drive untill of course you have to stop again.
My question is- is it the master cylinder or brake booster or what ?
Also the front sway bar bushings have turned into black goo and
fallen off the car. This is the second time this has happened. On the
coupes I have owned the bushings never have turned to goo but they
only have one side bulged into the little bumper. I though they would
look weird on a sedan. Has anyone had any luck with regular sway bar
bushings? I hate to buy 2 more sedan bushings just to have them fall
off again.
I am selling the AN600 if anyone is interested. Info by request.
Located in College Station Texas.
isettakurt
Re: sedan brake help
Post by isettakurt »
Nine times out of ten, it is the check valve on the master cyclinder outlet to the brake line that keeps the brakes
locked up.
Hi Dave and walshes600;
The check valve can most certainly be the culprit, but most often, the
bleed back hole in the master cylinder has caused the brakes to lock up and
then release. However I did have a front brake hose lock up one caliper
leaving all the others free. And, another time some one forgot to put the
pin on the end of the piston assembly for the booster on a coupe that didn't
allow the front system to release. Do you see what I am getting at. rework
the system, all of it. And then, if there is a problem, find it, and fix
it. Because right now it may be locking up but later it may allow your
peddle to sit on the floor. Then you might be feeling another experience in
"stopping your car mode..." the quick one right after you hit the guy in
front of you.
cmmwpi
Post by cmmwpi »
Thanks everyone for the info on my brake problem!
It still doesn't release the fronts after I bled the
system good. I also moved the pistons on the calipers
to see if they were moving freely ... they are. I
guess I will be pulling the master cylinder and brake
booster next.
I would like to sell it rather than work on it at
this point. Time and money constraints you know!
thanks again
John Walsh
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
http://promotions.yahoo.com/new_mail
brecountm
Post by brecountm »
walshes600 wrote:
> Hello!
>   I have a just short of fully restored sedan that i recently got > going again.It runs and looks great  but the front brakes don't > release enough after stopping or slowing down. The only way to get > them to release fully is to jab at the brake pedal hard. This seems to > free them up enough to drive untill of course you have to stop again.
>    Also the front sway bar bushings have turned into black goo and > fallen off the car. This is the second time this has happened. On the > coupes I have owned the bushings never have turned to goo but they > only have one side bulged into the little bumper. I though they would > look weird on a sedan. Has anyone had any luck with regular sway bar > bushings? I hate to buy 2 more sedan bushings just to > have them fall > off again.
What condidtion is the AN600 In College Station.  I am restoring one now.  Do you have photos?  What is your asking price.  I am outside of Houston.
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
Try looking at your brake hoses, they may be plugged.
> D Duniphin
> [mailto:dduniphin57@...]
> Monday, July 26, 2004 7:29
> [2cylinderhondas] sedan brake help
> walshes600
> > Hello!
> > recently got
> > brakes don't
> > release enough after stopping or slowing down. The only way > > to get > > them to release fully is to jab at the brake pedal hard. This > > seems to > > free them up enough to drive untill of course you have to stop > > again.
> > My question is- is it the master cylinder or brake booster or what > > ?
> > into black goo and
> > happened. On the
> > goo but they
> > only have one side bulged into the little bumper. I though > > they would > > look weird on a sedan. Has anyone had any luck with regular > > sway bar > > bushings? I hate to buy 2 more sedan bushings just to have them > > fall > > off again.
> What condidtion is the AN600 In College Station.  I am restoring one > now.  Do you have photos?  What is your asking price.  I am > outside of Houston.
> Do you Yahoo!?
> New
