Found parts in my trunk
LoganCashwell
Post by LoganCashwell »
I just broke into my car's trunk and found four unopened boxes of
origional Honda parts: 91051-538-028
Any idea what they are??
-Logan
riceburner006
Re: Found parts in my trunk
Post by riceburner006 »
--- In 2cylinderhondas@yahoogroups.com, "LoganCashwell"
> -Logan
Front wheel bearings or maybe 4 new crankshafts!!
LoganCashwell
Sweet. I thought they might be bearings. A nice round shape and
all. I didn't want to break the seals to look.
Can these parts still be acquired from Honda?
-Logan
Hi Logan;
The numbers cross over to other bearings. All new bearings are good,
and should perform well. I have found the catch being removing them. And
then look at where the bearing was seated. Normally there is some wear
making the bearings bounce in the housing. So don't just measure the
outside edge, measure the inside dia. of the bearing seat. If it is larger,
then you will have to dimple the surface with a punch so there will be no
movement.
