More information on the Restored sedan I have for sale.
Recent respray factory green
White racing stripe across the hood.
Yokohama A008 new tires
Cosmic powdered coated and polished wheels
Stainless steel exhaust
New Koni rear shocks
NOS front struts
NOS ball joints
NOS tie rod ends
NOS steering rack
NOS control arm bushing
New Sway bar bushings, better than NOS
NOS brake rotors
Rebuilt calipers
Rebuilt wheel cylinders
Rebuilt Brake booster
Rebuilt master cylinder
DOT approved braided front brake lines and the rear brake line also
NOS front and rear wheel bearings
NOS rear brake shoes
New front brake pads
Rebuilt lifetime warranty CV joints
New front and rear window weatherstripping with new chrome trim
NOS door weatherstripping
NOS door kick plates
NOS door trim
New carpet
Rechromed front and rear bumper
Rechromed grille
NOS headlight brackets
Enging rebuilt with NOS crankshaft, NOS seals, NOS transmission main bearing, NOS primary drive, includes both sprockets,dampners, chains, tensioner, oil pump bearing, custom made oil pump rod with press fit for oil pump piston pin, oil pump body resleeved in brass. Custom made pistons and rings 1.00 mm oversize. Hawaiian style head, nos valves, NOS cam chain slipper, nos lower cam chain roller, nos chain guide rollers, heavy duty cam chain. The engine subframe is powder coated along with everything attached to it. Over $10,000 and still counting,
I also have a 1989 Honda Crx SI ZC show car for sale, over $33,000 invested, this car was on the cover of the may issue of Honda Tuning. $12,500.00
Somebody bring a couple of trucks and lots of cash can take it all. Cars and parts located in North Carolina.
