twincarb
twincarb600
twincarb
Post by twincarb600 »
Bill,
The pic's were ones that I sent you a couple years back. The head is
a 360. It has been machined on and the stock 600 cylinders,upper
lower case modified for the change in oil flow to the cam area. The
bolt patterns are the same and from the pics the rust stain on the
head is from the 600 cylinders sleeves. I think that I also sent you
pic's of the modified pistons that were cut down and the domes
modified to match the different combustion camber. I still havn't
had time to piece the engine together and check it out. I think that
this is probably the same head that Miles has mentioned that Kefurt
had in the early 80's. I seen that head and pistons that he had and
it was a 360. He had head and cam housing and carbs. He tried telling
me about how special it was but I knew better. He also tried telling
me about the 180 crank, but he would never show that to me. (don't
think it exsists) One day I'll put the motor together and see what
happens.
Robert
