Repaint opinions sought...
asofdjhkljashdl
Post by asofdjhkljashdl »
Hi everyone. I'm looking for input on the following things before I paint
my car. It's a major color change I'm making from a Lime Green to a bright
Red. Please email me directly at by clicking
mailto:dstark@... with your opinion on the following three
matters:
1) I am VERY concerned about removing the Honda metal decals, side and
rear lights from the car. This car has been repainted before with these
things left on and I'm afraid that if I remove them I will damage them and
never get them back on properly. Do you think its a BIG mistake to paint
the car without removing them first? I know the ideal thing is to take
them off but the rubber gaskets are very old and the car is a New England
car so it has rust here and there and I'm very weary about this.
2) The chrome around the lights is very dull and "pitted". I have tried
chrome polish with a rag rubbing by hand but it makes no difference at
all. I suspect my only hope would be to send them in for re-chrome which
would require I remove them. I have a dremmel tool and could possibly try
polishing them in place, but I don't know what to use for polish and I
suspect it would make very little difference in the end. What do you think?
3) I'm trying to decide whether or not to keep the side chrome molding on
my car. It's a bit bent up here and they are a pain to put on and off
without scratching the car. I've seen other's that have removed the trim,
filled the holes and just painted. The earlier cars did not even have the
trim at all any way. Should I just remove them? Or do you think they add
a lot to the car?
Thanks for your opinions. I appreciate them.
Doug
Douglas Stark
STARK CONSULTANTS, INC.
One Memorial Square, Whitinsville, MA 01588
http://www.starkconsult.com XXX-XXX-XXXX
martykart
Re: Repaint opinions sought...
Post by martykart »
get rid of the green first cause it would make the red not as good if you used it as a bse coat.
marty
Joseph Corsinita
Post by Joseph Corsinita »
Get rid of the Green, Sand it down and give it a good coat of
2K-Primer
Jose
Well Doug;
It all depends on what type of finished product you want. If you remove
everything, you will find that lime green was not the first color either.
And, when you start from scratch, it always looks like you did the whole
thing and not just what you can see. Then there is expense, but what the
heck, you can't take it with you. You sound like some one that will not be
satisfied with a half way job, and if you know there is rust, the dig it
out, remove all the chrome. As the Chrome shop said, look for better parts.
Remove the emblems, rubber, door handles, stainless around the roof rails
even the trunk hinges. Pull the head light housings and have them gold zinc
or cad plated you will be surprised the difference it makes.
Here is a question for you. What type of car would you put the attached
engine in?
