Does anyone rebuild the vacuum assist brake unit? I had one rebuilt here in Southern California but it is faulty again. It appears that one or both of the diaphragms are damaged and leak brake fluid into the carburetor creating huge clouds of blue smoke. Or does anyone know where replacement diaphragms might be found?
I am located in the greater Los Angeles area of Southern California.
Garth
Vacuum assist brake unit
Gary Prince
Re: Vacuum assist brake unit
Karps brakes in Upland CA
On Nov 20, 2018 11:30 AM, "Stephen Garth Sorensen
sharonnjoy@...
> Thanks,
> Garth
Thanks. I'll check it out.
[anzhonda600owners]" < anzhonda600owners@yahoogroups.com
Karps brakes in Upland CA On Nov 20, 2018 11:30 AM, "Stephen Garth Sorensen sharonnjoy@...On Tuesday, November 20, 2018, 1:45:39 PM PST, Gary Prince gcprince@... [anzhonda600owners] wrote:
Garth
Would be great if you can post how you get on, watching with interest!
Thanks. I'll check it out.On Tuesday, 20 November 2018, 22:36:20 GMT, Stephen Garth Sorensen sharonnjoy@... [anzhonda600owners] wrote:
Garth
Here's what's inside your coupe & one type sedan booster. Bill Colford alerted me I forgot to show the
actuator pin that goes into end of piston.
https://www.facebook.com/pg/600guru/pho ... 0897243347
