cleaning
Greg Prentice
cleaning
Hello all.
I have my N600 engine torn apart and have started tackling the parts cleaning.
Does anyone have an easy method to clean cooling fins – maybe soaking the cyinder barrel in something??
Thanks.
Greg Prentice
Toromont Power Systems
This e-mail and any attachments may be confidential or legally privileged. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited. Please notify us immediately by email at corpmail@...
or by telephone (collect if necessary). Please delete this email and destroy any copies. Thank you for your cooperation.
Toromont Industries Ltd., 3131 Highway 7 West, Concord, ON, L4K 1B7 www.toromont.com XXX-XXX-XXXX.
Ce courriel, ainsi que tous les fichiers joints, sont consid�r�s comme confidentiels ou juridiquement privil�gi�s. Si vous n'�tes pas le destinataire d�sign� du pr�sent message, soyez avis� que toute divulgation, copie, distribution ou action se fondant sur le contenu est strictement interdite. Veuillez nous en aviser imm�diatement par courriel � l'adresse corpmail@...
ou par t�l�phone (� frais vir�s si n�cessaire). Veuillez effacer ce courriel et toute copie �ventuelle. Merci pour votre coop�ration.
XXX-XXX-XXXX.
Thanks.
Greg Prentice
XXX-XXX-XXXX.
Bob Prentice
Re: cleaning
Spray Varsol, Small wire brush and patience. There's no easy way. You should know that by now! �rp
On Tue, Feb 16, 2016 at 8:49 PM, Greg Prentice
GPrentice@...
[anzhonda600owners]
> Hello all.
> Does anyone have an easy method to clean cooling fins maybe soaking the cyinder barrel in something??
> Thanks.
> Greg Prentice
> XXX-XXX-XXXX
> This e-mail and any attachments may be confidential or legally privileged. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of > this information is strictly prohibited. Please notify us immediately by email at
> corpmail@...
> �or by telephone (collect if necessary). Please delete this email and destroy any copies. Thank you for your cooperation.
> www.toromont.com
> XXX-XXX-XXXX
> Ce courriel, ainsi que tous les fichiers joints, sont consid?r?s comme confidentiels ou juridiquement privil?gi?s. Si vous n'?tes pas le destinataire d?sign? du pr?sent message, soyez avis? que toute divulgation, copie, > distribution ou action se fondant sur le contenu est strictement interdite. Veuillez nous en aviser imm?diatement par courriel ? l'adresse
> corpmail@...
> ou par t?l?phone (? frais vir?s si n?cessaire). Veuillez effacer ce courriel et toute copie ?ventuelle. Merci pour votre coop?ration.�
> www.toromont.com
> XXX-XXX-XXXX
Re: cleaning
I used a transmission shop to clean them, but they still came out different shades of gray, not shinny.
Jeanie Tucker
Re: cleaning
As for most parts cleaning I have a "Benchtop pro" a really good cleaning system. I am at the point of cleaning my cooling fins also and was HOPING that bead blasting would work. I also have an aluminim cleaner from NAPA called alluminim brightner, I am not really thrilled with it.I can smell acid in it so maby??????? a mild meriatic acid??? any thoughts on mild acid besides be safe. thanks Jay
Note: 1 image(s) originally linked in this post are no longer available (ec).> ----- Original Message -----
> Greg Prentice
> GPrentice@... [anzhonda600owners]
> Tuesday, February 16, 2016 8:49
> [anzhonda600owners]
> cleaning
> Hello all.
> I have my N600 engine torn apart and have started tackling > the parts cleaning.
> Does anyone have an easy method to clean cooling fins �
> Thanks.
> Greg Prentice
> XXX-XXX-XXXX
> confidential or legally privileged. If you are not the intended recipient you > are notified that disclosing, copying, distributing or taking any action in > reliance on the contents of this information is strictly prohibited. Please > notify us immediately by email at > corpmail@...
> or by
> telephone (collect if necessary). Please delete this email and destroy any > copies. Thank you for your cooperation.
> www.toromont.com
> XXX-XXX-XXXX.
> joints, sont consid�r�s comme confidentiels ou juridiquement privil�gi�s. Si > vous n'�tes pas le destinataire d�sign� du pr�sent message, soyez avis� que > toute divulgation, copie, distribution ou action se fondant sur le contenu est > strictement interdite. Veuillez nous en aviser imm�diatement par courriel � > l'adresse > corpmail@...
> ou
> par t�l�phone (� frais vir�s si n�cessaire). Veuillez effacer ce courriel et > toute copie �ventuelle. Merci pour votre coop�ration.
> Toromont
> Industries Ltd., 3131 Highway 7 West, Concord, ON, L4K 1B7 > www.toromont.com > XXX-XXX-XXXX.
> This email is free from viruses and malware because
> avast! Antivirus
> protection is active.
Greg Prentice
Re: cleaning
I have used oven cleaner to clean aluminum parts with great success with no damage to surfaces. I will try that on the fins.
Re: cleaning
The transmission shop uses a citric acid solution in their cleaning rack. Parts are hung on the rack with the solution sprayed under pressure to cut through the crud. But even then not everything is removed and there is some scraping. However all the grease is gone. Glass bead like sand blasting gets into everything and everything then needs to be cleaned again. But as I said earlier, any acid causes everything to come out in different shades of gray. So I paint the exterior of the engine cases, cylinders and such to give them a fresh aluminum look.
Harry Lineback
Re: cleaning [1 Attachment]
GREAT advice Mr.Bill....you "stuff" looks very SUPER nice.
Harry Lineback XXX-XXX-XXXX mobile
On Wednesday, February 17, 2016 7:50 AM, "'Bill' billmyong@... [anzhonda600owners]" wrote:
[ Attachment(s) from Bill included below]
Bryan O_Shaughnessy
Re: cleaning
Harry: Bill's advice is good, but I would caution you to BE SURE that any threads or oil-passages are plugged up when giving parts any "blasting" treatment. You don't want any leftover sand or beads floating around or blocking things. Just a caution. --Bryan
Note: 1 image(s) originally linked in this post are no longer available (ec).> From:
> "Harry Lineback harryl1190@... [anzhonda600owners]"
> "anzhonda600owners@yahoogroups.com"
> Wednesday, February 17, 2016 9:54 AM
> Re: [anzhonda600owners] cleaning
> Attachment(s)
> uses a citric acid solution in their cleaning rack. Parts are hung on the > rack with the solution sprayed under pressure to cut through the crud. But > even then not everything is removed and there is some scraping. However > all the grease is gone. Glass bead like sand blasting gets into everything > and everything then needs to be cleaned again. But as I said earlier, any > acid causes everything to come out in different shades of gray. So I > paint the exterior of the engine cases, cylinders and such to give them a fresh > aluminum look.
> Wednesday, February
> 17, 2016 7:26 AM
> RE: [anzhonda600owners]
> cleaning
> I have used
> oven cleaner to clean aluminum parts with great success with no damage to > surfaces. I will try that on the fins.
> Wednesday, February
> 17, 2016 8:31 AM
> cleaning
> have a "Benchtop pro" a really good cleaning system. I am at the point of > cleaning my cooling fins also and was HOPING that bead blasting would work. I > also have an aluminim cleaner from NAPA called alluminim brightner, I am not > really thrilled with it.I can smell acid in it so maby??????? a mild meriatic > acid??? any thoughts on mild acid besides be safe. thanks > Jay
> > Greg Prentice
> > PM
> > Hello all.
> > I have my N600 engine torn apart and have started tackling > > the parts cleaning.
> > Thanks.
> > Greg Prentice
> > XXX-XXX-XXXX
> > This e-mail and
> > any attachments may be confidential or legally privileged. If you are not the > > intended recipient you are notified that disclosing, copying, distributing or > > taking any action in reliance on the contents of this information is strictly > > prohibited. Please notify us immediately by email at > > corpmail@...
> > or by
> > telephone (collect if necessary). Please delete this email and destroy any > > copies. Thank you for your cooperation.
> > www.toromont.com
> > XXX-XXX-XXXX.
> > Ce courriel,
> > ainsi que tous les fichiers joints, sont consid�r�s comme confidentiels ou > > juridiquement privil�gi�s. Si vous n'�tes pas le destinataire d�sign� du > > pr�sent message, soyez avis� que toute divulgation, copie, distribution ou > > action se fondant sur le contenu est strictement interdite. Veuillez nous en > > aviser imm�diatement par courriel � l'adresse > > corpmail@...
> > ou par t�l�phone
> > (� frais vir�s si n�cessaire). Veuillez effacer ce courriel et toute copie > > �ventuelle. Merci pour votre coop�ration.
> > www.toromont.com
> > XXX-XXX-XXXX.
> > malware because
> > avast!
> > Antivirus
Re: cleaning
Hi Greg,
What is your goal on the engine cleaning? Is it to clean off the grime and improve the heat transfer or are you trying to achieve a "new" look? The Honda 600 engines had a coating on the aluminum which turns yellow/brown/dull gray with age.
If you want to clean it to improve the heat transfer, you can use cleaners such as Gunk or steam clean it or use a brush & solvent. The aluminum will still be dscolored. You can also have an engine machine shop cold tank it for you in their cleaning solution.
If you are looking for the new look, you can clean up as described above and then have it bead blasted. This will remove the coating but will give you the new look. Without the coating, you will be not have the aluminum protection unless you find another coating or spend lots of money to have the aluminum anodized.
Note: 1 image(s) originally linked in this post are no longer available (ec).> > From:
> > Greg Prentice
> > PM
> > [anzhonda600owners]
> > cleaning
> > Hello all.
> > Thanks.
> > Greg Prentice
> > XXX-XXX-XXXX
> > This e-mail
> > and any attachments may be confidential or legally privileged. If you are > > not the intended recipient you are notified that disclosing, copying, > > distributing or taking any action in reliance on the contents of this > > information is strictly prohibited. Please notify us immediately by email at
> > corpmail@...
> > or by
> > www.toromont.com
> > XXX-XXX-XXXX.
> > Ce courriel,
> > ou par
> > t�l�phone (� frais vir�s si n�cessaire). Veuillez effacer ce courriel et > > toute copie �ventuelle. Merci pour votre coop�ration.
> > Toromont
> > Industries Ltd., 3131 Highway 7 West, Concord, ON, L4K 1B7 > > www.toromont.com
> > XXX-XXX-XXXX.
> > malware because
> > avast! Antivirus
> > protection
> > is active.
Greg Prentice
Re: cleaning
Thanks Dale.
My reasons are all cosmetic..
I will try the things you suggest.
Thanks again&.
Note: 1 image(s) originally linked in this post are no longer available (cid:~WRD000.jpg).
Thanks again&.
