Help with Paint code
jmurrayr6
Post by jmurrayr6 »
I want to make sure I get the correct code. I am in need of the cream yellow color. I will be using sherwin williams auto paint. Thanks guys
mterrens
Re: Help with Paint code [1 Attachment]
Post by mterrens »
You can start here...
http://www.honda600coupe.com/Honda_600_ ... _codes.pdf
On Wed, Jan 27, 2016 at 05:05 PM, jmurray192@... [anzhonda600owners] wrote:
> Attachment(s)
> from jmurray192@... [anzhonda600owners] included below]
The paint code chart is a good place to start.  Your car is the spring yellow color.  Having the paint code does not guarantee a perfect color match.  You might consider selecting an inside area of your car's paint which hasn'
In a message dated 1/28/2016 5:27:18 A.M. Pacific Standard Time, anzhonda600owners@yahoogroups.com writes:
> > Attachment(s)
> > I want to make sure I get the correct code. I am in need of the > > cream yellow color. I will be using sherwin williams auto paint. Thanks > > guys
> place to start.  Your car is the spring yellow color.  Having the > paint code does not guarantee a perfect color match.  You might consider > selecting an inside area of your car's paint which hasn't seen much fading and > have a paint shop match to that color.  Hoping you get a paint job which > satisfies you.
> > Attachment(s)
Dale is correct, and I found that unless the paint supplier has the old codes they really don't help.  So as Dale said, finding an unexposed area to match may be the best bet.  If any other Honda 600 owners have had the paint matched maybe they have the correct code for that paint manufacturer.
jmurrayr6
Post by jmurrayr6 »
ok ill give her a shot. Thanks guys
