Hi Toni;
Great video and well done on the sound pickup through the stethoscope. It sounds like there is more associated noise from metal hitting metal in the cam area. What are the settings? If your rocker arms are more than .004 then there will be more noise. How does it sound with a few more RPM's?
Also your engine seems to be surging at idle a condition normally associated with dirty carb jets or the point’s breaker plate is warn.
And how are the springs on the advancer assembly?
Re: [2cylinderhondas] noise test with stethoscope
I have a NOS head gasket. 100$ plus shipping.
PRG-Nocturne
Egeiger@...
PRG-Nocturne
Egeiger@...
Note: 1 image(s) originally linked in this post are no longer available (ec).On May 12, 2014, at 4:59 PM, "Toni Perez
tonipereztf@...
[2cylinderhondas]" wrote:
Bill:
Cams valves are tight. Everything seems normal valves. The noise is accompanied by a vibration. Now I will disassemble the engine and hope to find fault.
Only one problem: I have not head gasket, or parts for the crankshaft.
I hope that in the group you can find what you need.
A greeting.
Toni.
El Lunes, 12 de mayo, 2014 3:13 P.M., "'Bill'
billmyong@...
[2cylinderhondas]" escribi�:
Hi Toni;
Also your engine seems to be surging at idle a condition normally associated with dirty carb jets or the points breaker plate is warn.
Monday, May 12, 2014 6:02 AM
Hello people.
Someone with a good ear to tell the diagnosis?
thank you very much
Honda z600 engine test crankshaft stethoscope
Honda
This feature is not available right now. Please try again later.
View
on
www.youtube.com
Preview by Yahoo
