, goinhm@... wrote:
> It looks like your wish may come true. The auto industry appears to have
> been looking into absorption refrigeration systems for some time. I get
> the impression it was not adopted for the gas-powered cars because the system
> is more expensive (and may be more hazardous because of the chemicals
> used) than the systems currently found in cars. The current air conditioning
> systems require you to use a little more fuel but it doesn't impact the mpg
> ratings which the gov't watches (but it does impact the mpg rating you
> observe) and it lets the auto industry get by with a less expensive system.
> As electric vehicles pick up in popularity, the existing air conditioning
> systems are not going to work so well since they will drain the battery
> quicker. Since you probably want the air conditioner on when it is hot outside
> (due to lots of solar heat), the solar-powered absorption refrigeration
> system may be the ticket to a cool ride. I noticed Ohio State University
> has lots of info on stuff they are doing with this process and they have a
> close alliance with the American auto industry.
> thanks for bringing this to our attention,
> I wonder what is stopping Auto. design engineers from developing an air
> conditioning system of the Electrolux absorbtion type ? The engine exhaust
> system should be able to supply more than enough heat !
