I'm currently running a fuel pump off a 83 VF750c Magna Honda motorcycle.
The only difference from the original is the angle the hoses connect at but its close enough to work with a little re routing. Mounting is the same. You may have to chage the electrical connector if I remember right.
Al Loring 71 AZ 600
