600 has no spark
tbwills
600 has no spark
Post by tbwills »
I'm trying to get my little 600 coupe going again, I just put on a new
carb, and now I have no spark at the plugs, I'm showing power to the
distribitor, coil and point, but nothing at the plugs, anyone have any
ideas? any help greatly needed.
jennings93463
Re: 600 has no spark
Post by jennings93463 »
You could try changing the capacitor, Is your battery completely
charged? Check that everything is connected tightly. Do you have a
Haynes manual?
tbwills
Post by tbwills »
--- In anzhonda600owners@yahoogroups.com, "jennings93463"
> Haynes manual?
The battery is charged, and all connections seem to be thight. What is
the capacitor? I do have an old Cliltons which covers the 600 and the
Civic, it can get a little confussing with it covering both cars.
jennings93463
, "jennings93463"
> new
> the
> any
> > Haynes manual?
>the capacitor is the small, metal, cylindrical, thing inside the
breaker housing sitting next to the points. in the haynes manual it
says one way to check if it's bad, is to turn on the ignition,and
seperating the points by hand,while doing this if there is a blue
flash between the points, the capacitor( condenser) is probably bad.
I'm just guessing but you need to check everything and that is just
one of many things
tdthies1
Post by tdthies1 »
the same thing happen to mine when i bought it last month and after a
lot of time checking this and that. it turned out that it was the
points. I took a fingernail file and filed it on the top and bottom
and tryed to fire it up and ran. take the spark plug out and place it
so it can ground then short the hot side of the points to ground and
you should get a spark. if you do it is the points.
hope this helps.
tom
