Does anyone happen to have a spare plastic bracket that the Coupe's rear-view mirror attaches to? It is bolted to the roof, hidden behind the center console. Here a picture...
http://www.honda600coupe.com/mirror_bracket.gif
Mine is cracked in half. I will attempt to repair it with epoxy if I must but a good one would definately be better.
misc. Coupe part needed
Re: misc. Coupe part needed
Hi Steve
I also need the same part. My car is a 1971 1300 Coupe 9, but I think that the part is the same. In my parts book the part number is 88145-579-000.
I you get a spare one, could you let me know.
Regards
Regards
> Thanks,
> Steve
Send instant messages to your online friends http://au.messenger.yahoo.com
Hi Steve;
Try Honda part numbers 88145-673-101-ZA or 88145-657-602-ZB, I have both numbers written down and I believe they are different colors. Or one is a bottom spacer, anyway it's a start.
> Steven
> Michelsen
> Tuesday, October 04, 2005 6:05 PM
> Honda group - anzhonda600owners; Honda group -
> 2cylinderhondas
> [anzhonda600owners] misc. Coupe part
> needed
> bracket that the Coupe's rear-view mirror attaches to? It is bolted to > the roof, hidden behind the center console. Here a > picture...
> repair it with epoxy if I must but a good one would definately be > better.
> Thanks,
> Steve
Hi Bill,
I must confess that I rarely consider just calling Honda. I gave my local dealer a call , but unfortunately the two numbers you listed "were not Honda part numbers" (at least according to thier database). The part number I have here from the parts catalog (88140-623-670), which is for the bracket and the mirror as an assembly, turned up as not available. The bracket is not listed separately.
This leads me to a question: What is the proper technique for removing the center console? I need to get at the rest of that bracket, and don't want to do any damage!
By the way, when I get the bracket out, I may have another part number to ask for. There is the beginning of a number printed on the bit that broke off. Here is a picture of the back (top) side of the piece...
http://www.honda600coupe.com/broken_mirror_bracket.jpg
Take the ZA or ZB off. These numbers are for the 1978 civic. they used the same bracket. And the numbers are good. I checked them out. Maybe you need a new Honda parts guy.
> Steven
> Michelsen
> Wednesday, October 05, 2005 7:51 AM
> Re: [anzhonda600owners]
> Hi Bill,
> , but unfortunately the two numbers you listed "were not Honda part > numbers" (at least according to thier database). The part number I > have here from the parts catalog (88140-623-670), which is for the > bracket and the mirror as an assembly, turned up as not available. The > bracket is not listed separately.
> This leads me to a question: What is the proper technique for > removing the center console? I need to get at the rest of that bracket, > and don't want to do any damage!
> have another part number to ask for. There is the beginning of a number > printed on the bit that broke off. Here is a picture of the back (top) > side of the piece...
> Steve
> > Colford
> > Wednesday, October 05, 2005 3:40
> > AM
> > RE: [anzhonda600owners] misc.
> > Coupe part needed
> > Hi
> > Steve;
> > 88145-657-602-ZB, I have both numbers written down and I believe they > > are different colors. Or one is a bottom spacer, anyway it's a start.
> > > On Behalf Of
> > > Steven
> > > Michelsen
> > > Sent:
> > > 2cylinderhondas
> > > needed
> > > bracket that the Coupe's rear-view mirror attaches to? It is bolted > > > to the roof, hidden behind the center console. Here a > > > picture...
> > > to repair it with epoxy if I must but a good one would definately be > > > better.
> > > Thanks,
> > > Steve
Steve,
The mirrors from Civics 73-76 fit the sedans (sun visors won't go down, but it's a small sacrifice). The bracket may be close enough. While you're at the wrecking yard, grab the window cranks, they fit too.
> Hi Bill,
> I must confess that I rarely consider just calling Honda. I gave my local dealer a call > , but unfortunately the two numbers you listed "were not Honda part numbers" (at least according to thier database). The part number I have here from the parts catalog (88140-623-670), which is for the bracket and the mirror as an assembly, turned up as not available. The bracket is not listed separately.
> Steve
> > Bill Colford
> > Wednesday, October 05, 2005 3:40 AM
> > RE: [anzhonda600owners] misc. Coupe part needed
> > Hi Steve;
> > > On Behalf Of
> > > Steven Michelsen
> > > Sent:
> > > Honda group - anzhonda600owners; Honda group - 2cylinderhondas > > > Subject:
> > > Thanks,
> > > Steve
Bill,
I called my local dealer again and asked about those two numbers, without the ZA or ZB. He couldn't find either of them on any database. What's worse, I went to http://www.torringtonhondaparts.com/ and it appears that that website is "off the air". They had been a good source in the past. If you can pass along the tel number of the dealer that has this part, I would appreciate it.
> Colford
> Wednesday, October 05, 2005 11:21
> Coupe part needed
> Take
> the ZA or ZB off. These numbers are for the 1978 civic. they used > the same bracket. And the numbers are good. I checked them > out. Maybe you need a new Honda parts guy.
> > On Behalf Of
> > Steven
> > Michelsen
> > Hi Bill,
> > "were not Honda part numbers" (at least according to thier > > database). The part number I have here from the parts > > catalog (88140-623-670), which is for the bracket and the mirror as an > > assembly, turned up as not available. The bracket is not listed > > separately.
> > This leads me to a question: What is the proper technique for > > removing the center console? I need to get at the rest of that > > bracket, and don't want to do any damage!
> > have another part number to ask for. There is the beginning of a > > number printed on the bit that broke off. Here is a picture of the > > back (top) side of the piece...
> > Steve
> > > Bill Colford
> > > Sent:
> > > 3:40 AM
> > > Hi Steve;
> > > 88145-657-602-ZB, I have both numbers written down and I believe > > > they are different colors. Or one is a bottom spacer, anyway it's a > > > start.
> > > Bill
> > > > From:
> > > > On Behalf Of
> > > > Steven
> > > > Michelsen
> > > > Sent:
> > > > PM
> > > > To:
> > > > 2cylinderhondas
> > > > Subject:
> > > > needed
> > > > bracket that the Coupe's rear-view mirror attaches to? It is > > > > bolted to the roof, hidden behind the center console. Here a > > > > picture...
> > > > attempt to repair it with epoxy if I must but a good one would > > > > definately be better.
> > > > Thanks,
> > > > Steve
