wanted: Clutch Cable z600
Franco
Post by Franco »
Can anyone tell me where I can buy a clutch cable for a 72 z600?
Jim
Re: wanted: Clutch Cable z600
Hi Jim;
Normally the cable housing is ok, just the cable its self. Save all of the
old cable as you will need it to make a new one. Then go to a Harley
Davidson dealer or parts shop and find one the same or close to the length
you need. then cut it and put the new end on it. Make sure you do not just
cut it, it has to be ground off with a cutting disk. Reassemble and your on
the road.
