were i can find carburetor diaphragm?
Hi, i have 3 honda Z600, my father bought the first in 1974, since that date we own 16 z600 and sedans, i have a yellow and a orange coupe, they have old style carburetors i can`t identify, but i need the diaphragms and orings
I will need advice to find tires, camchain roller, head gasket
If cant ,i am thinking in use an atv efi system ( honda rancher 420 )
First, identify this carburetors and parts to make it run, tires are second, third will be the front windshield.
Re: were i can find carburetor diaphragm?
http://honda600carparts.com/fuel-system.html
The cam chain is a common Kart drive chain
I just got a couple of Ohtsu 145/10C 6 ply from a local dealer (farming area) Dealer said he stocks them for some kinds of farm implement that has them on outrigger/jockey wheels.
Head gasket can be reused if in reasonable condition.
Chuck Dean
Tires:
https://www.7ent.com/categories/wheels-tires/tires.html
Our 1972 Honda 600 Coupe Our 1961 Vespa 400
On Aug 7, 2019, at 8:14 PM,
micmec68@...
Hi, i have 3 honda Z600, my father bought the first in 1974, since that date we own 16 z600 and sedans, i have a yellow and a orange coupe, they have old style carburetors i can`t identify, but i need the diaphragms and orings I will need advice to find tires, camchain roller, head gasket If cant ,i am thinking in use an atv efi system ( honda rancher 420 ) First, identify this carburetors and parts to make it run, tires are second, third will be the front windshield.
Where are you located?
I think at least one of Hondas EFI systems would work. You are in the right place to get help.
I suggest you contact Mike OConnor for everything you need.
Rick Morris Sent from my iPhone
On Aug 7, 2019, at 7:14 PM,
micmec68@...
dusty path
on the carbs why not update to newer carb and if ur looking for a windshield for AN600 sedan I know were u can get new and rubber u can get on ebay also the carbs and if u looking for tires I will get the link for all of that
Hi, i have 3 honda Z600, my father bought the first in 1974, since that date we own 16 z600 and sedans, i have a yellow and a orange coupe, they have old style carburetors i can`t identify, but i need the diaphragms and orings I will need advice to find tires, camchain roller, head gasket If cant ,i am thinking in use an atv efi system ( honda rancher 420 ) First, identify this carburetors and parts to make it run, tires are second, third will be the front windshield.On Wednesday, August 7, 2019, 06:35:28 PM MDT, micmec68@... [2cylinderhondas] wrote:
Bram Evenhuis
Hi, you mean the diaphragm for accelleration pump?
I believe he is asking about the Piston Diaphragm (see attached)
evenhuisbram
what nr. ( f.i. 6NM) is on the left side on the carb housing? In front of the piston.
what nr. ( f.i. 6NM) is on the left side on the carb housing? In front of the piston.On Friday, August 9, 2019, 02:52:32 AM CDT, b.evenhuis@... [2cylinderhondas] wrote:
