72 Sedan fuel sender ohm reading gauge not reading correct
lt1ski
Post by lt1ski »
Hello all , My fuel sender is only reading 3/4 tank on the gauge when its full , I pulled the sender and put a multimeter on it , it shows 4.2 ohms at empty and 131 ohms at full , does anyone out there know if this reading is correct and maybe my gauge is the problem ?   thanks so much for any input   cheers Dean M / Santa Cruz CA
rstevens19
Re: 72 Sedan fuel sender ohm reading gauge not reading correct
Post by rstevens19 »
According to the manual, normal is between 30 and 34 ohm for sender. Gage resistance should not exceed 100 ohms
lt1ski@... [2cylinderhondas]
Sunday, June 23, 2019 11:18 PM
[2cylinderhondas] 72 Sedan fuel sender ohm reading gauge not reading correct
Virus-free.
www.avast.com
bernardmorrison
Post by bernardmorrison »
Iam a retired ford tech,i use to check the guage by turning the key on unplug the sender goes to empty,  ground the hot wire at sender goes to full if so guage is good sender or wiring  bad. May be other way around with e and f . Dont do this unless someone more familiar  with this car says  its ok
Sent from my Galaxy Tab� E
-------- Original message -------- From: "lt1ski@... [2cylinderhondas]" Date: 6/23/19 11:18 PM (GMT-05:00) To: 2cylinderhondas@yahoogroups.com Subject: [2cylinderhondas] 72 Sedan fuel sender ohm reading gauge not reading correct
bernardmorrison
Correction ,if goes from e to f guage  and wiring  good sender bad
