Hi,.
I'm l ooking for any tips on checking/setting timing (tools needed and so forth) on my '72 Honda N600. Runs good but want to make sure everything (like points, timing, and valve clearance) are good for the Summer.
Checking/Setting timing on my 1972 Honda N600
Re: Checking/Setting timing on my 1972 Honda N600
You could be opening a can of worms on yourself. If it's running good, leave it alone - I would.
dustyspath
go here this tells u how to do it all but u will have to down load it u also can save it on ur PC if ur on one if on a cell u will also have to down load other thing to make it work it takes time to open
http://www.honda600coupe.com/Manuals,_b ... ments.html
james brown
This is perfect, Thanks again
go here this tells u how to do it all but u will have to down load it u also can save it on ur PC if ur on one if on a cell u will also have to down load other thing to make it work it takes time to open http://www.honda600coupe.com/Manuals,_b ... ments.htmlOn Tuesday, June 18, 2019, 08:41:30 AM EDT, dustyspath@... [2cylinderhondas] wrote:
