Hi all, I have enjoyed being a group member and reading you post for several years. Finally bought a really nice 72 Z on Friday. It had been sitting for awhile, and then recently just idled around a dealer lot, onto the auction block, on and off my trailer, and such.
It starts and runs perfectly at idle, no smoke, clearly has compression and firing both cylinders correctly. It won't rev out under load. I am competent to figure it out and will begin going through all of the checks but am really hoping there is something common you all know from experience that I should check first.
Thank you. Curtis Wood
Running under load issue-anything common or obvioius
Don B Laughton
Re: Running under load issue-anything common or obvioius
Check ignition timing and advance (mechanical advance can lock up). Check condition of wires from coil to spark plug caps. Check for a foiled plug. Good luck.
Sent from my iPhone
Sent from my iPhone
On Oct 21, 2018, at 8:26 AM,
cgwood13@...
Fuel starvation? Maybe take the carb apart and clean or rebuild it. Todays fuels can gum it up fast.
Sent from my iPhone
Sent from my iPhone
On Oct 21, 2018, at 10:01 AM, Don B Laughton
dontranspac@...
Sent from my iPhone
cgwood13@...
Paige Hunt
When this happened to me, it was a faulty fuel pump. The damn thing was shiny and new, just defective. I replaced it with a regular style, as I've never been a fan of the old style clicker type. just make sure the pressure is low, and volume is high to avoid flooding.
ererveI'veSent from Yahoo Mail on Android
Curtis Wood
Thanks all. I have checked valve timing, lash, compression, ignition and ignition advance. All is good.
Really just feels like the throttle is only part open and because there is no coughing or spitting I doubt fuel pressure is a problem.
Is there a way to confirm the slide is lifting and pulling the needle jet up? Based on experience with SUs on British cars that seems likely.
Carb is next. Again thanks.
Sent from my iPhone
Sent from my iPhone
On Oct 21, 2018, at 12:40 PM, art Remai
artremai@...
Fuel starvation? Maybe take the carb apart and clean or rebuild it.. Todays fuels can gum it up fast.
Sent from my iPhone
dontranspac@...
> Check ignition timing and advance (mechanical advance can lock up).. Check condition of wires from coil to spark plug caps. Check for a foiled plug. Good luck.
> Sent from my iPhone
> cgwood13@...
> [2cylinderhondas] 2cylinderhondas@yahoogroups.com
Don B Laughton
Early carburetors have a vacuum piston with a rubber diaphragm. These diaphragms are known to tear. If your carburetor has a stamped steel top, you have a rubber diaphragm. Carbs with aluminum tops have a steel piston. Remove air cleaner to carb bellows and with a mirror watch to see if piston rises with engine speed. Steel pistons can get gummed up.
Good luck Sent from my iPhone
On Oct 21, 2018, at 4:11 PM, Curtis Wood
cgwood13@...
Sent from my iPhone
artremai@...
> Fuel starvation? Maybe take the carb apart and clean or rebuild it... Todays fuels can gum it up fast.
> Sent from my iPhone
> dontranspac@...
> > Check ignition timing and advance (mechanical advance can lock up)... Check condition of wires from coil to spark plug caps. Check for a foiled plug. Good luck.
> > Sent from my iPhone
> > cgwood13@...
> > [2cylinderhondas] > 2cylinderhondas@yahoogroups.com
Curtis Wood
Got it !! Thanks everyone. Not positive it was the carb piston but I removed the piston top cover, cleaned everything with fine emory cloth, then reassembled like an SU torqueing the cover bolts a little at a time while sliding the piston up and down. Fired it up and it runs like a top!
Fun first drive under the belt
Curtis
Curtis
On Sun, 10/21/18, Don B Laughton
dontranspac@...
Subject: Re: [2cylinderhondas] Running under load issue-anything common or obvioius
Date: Sunday, October 21, 2018, 6:56 PM
get gummed up.�Good luck
Sent from my
iPhone
On Oct 21, 2018,
cgwood13@...
[2cylinderhondas] <
good.�
Really just
problem.�
Is there a
jet up? �Based on experience with SUs on British cars that
seems likely.�
Carb
is next. Again thanks.�
Sent from my
iPhone
On Oct 21, 2018,
artremai@...
[2cylinderhondas] <
clean or rebuild it.... Todays fuels can gum it up
fast.
Sent from my
iPhone
On Oct 21, 2018,
dontranspac@...
[2cylinderhondas] <
advance can lock up).... Check condition of wires from coil
to spark plug caps. Check for a foiled plug. Good luck.�
Sent from my
iPhone
On Oct 21, 2018,
at 8:26 AM,
cgwood13@...
[2cylinderhondas] <
Hi all,� I have enjoyed being a group
member and reading you post for several years.� Finally
bought a really nice 72 Z on Friday.� It had been sitting
such.
cylinders correctly.� It won't rev out under load.� I
first.
Thank you. ��
Curtis Wood
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXX --
#yivXXX-XXX-XXXXygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px
0;padding:0 10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp hr {
border:1px solid #d8d8d8;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXhd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXads {
margin-bottom:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad {
padding:0 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad p {
margin:0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad a {
color:#0000ff;text-decoration:none;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor
#yivXXX-XXX-XXXXygrp-lc {
font-family:Arial;}
#yivXXX-XXX-XXXXygrp-lc #yivXXX-XXX-XXXXhd {
margin:10px
0px;font-weight:700;font-size:78%;line-height:122%;}
#yivXXX-XXX-XXXXygrp-lc .yivXXX-XXX-XXXXad {
margin-bottom:10px;padding:0 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span {
font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span:first-child {
text-transform:uppercase;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span a {
color:#5085b6;text-decoration:none;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span span {
color:#ff7900;}
.yivXXX-XXX-XXXXunderline {
text-decoration:underline;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
0;width:400px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach div a {
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach img {
border:none;padding-right:5px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label {
display:block;margin-bottom:5px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label a {
#yivXXX-XXX-XXXX blockquote {
margin:0 0 0 4px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold {
font-family:Arial;font-size:13px;font-weight:700;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold a {
#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p a {
font-family:Verdana;font-weight:700;}
#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
span.yivXXX-XXX-XXXXyshortcuts {
margin-right:0;}
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table div div a {
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table {
width:400px;}
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXfile-title a, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:active, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:hover, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:visited {
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:active,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:hover,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:visited {
#yivXXX-XXX-XXXX div#yivXXX-XXX-XXXXygrp-mlmsg
#yivXXX-XXX-XXXXygrp-msg p a span.yivXXX-XXX-XXXXyshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXgreen {
color:#628c2a;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXMsoNormal {
margin:0 0 0 0;}
#yivXXX-XXX-XXXX o {
font-size:0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div {
float:left;width:72px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div div {
border:1px solid
#666666;min-height:62px;overflow:hidden;width:62px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXreco-category {
font-size:77%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXreco-desc {
font-size:77%;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXreplbq {
margin:4px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean,
sans-serif;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg table {
font-size:inherit;font:100%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg select,
#yivXXX-XXX-XXXX input, #yivXXX-XXX-XXXX textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg pre, #yivXXX-XXX-XXXX
code {
font:115% monospace;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg * {
line-height:1.22em;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg #yivXXX-XXX-XXXXlogo {
padding-bottom:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-msg p a {
font-family:Verdana;}
p#yivXXX-XXX-XXXXattach-count span {
color:#1E66AE;font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco
#yivXXX-XXX-XXXXreco-head {
color:#ff7900;font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco {
margin-bottom:20px;padding:0px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXov
li a {
font-size:130%;text-decoration:none;}
li {
font-size:77%;list-style-type:square;padding:6px 0;}
ul {
margin:0;padding:0 0 0 8px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text {
font-family:Georgia;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text p {
margin:0 0 1em 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text tt {
font-size:120%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-vital ul li:last-child {
border-right:none !important;
#yivXXX-XXX-XXXX
