Resistance honda sparkplug cap
ronny lucassen
Post by ronny lucassen »
Hello
who knows how much the resistance of the ingition parts is from the N and Z ignition?
resistance coil?
resistance cable?
resistance sparkplugcap?
please let me know
thanks
ronny
Re: Resistance honda sparkplug cap
Post by Eric Geiger »
I just rebuilt 2 coils and checked resistance.   I know both I mine were identical but I can't remember off the top of my head now how much. I have to check my multi meter again and confirm but I can have an answer for you when I head to work tonight on the coil resistance.   I used copper core wire and the resistor ends that Bruce sells on his website.
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
On Jan 23, 2013, at 9:21 AM, "ronny lucassen" wrote:
Hello
resistance coil?
resistance cable?
please let me know
thanks
ronny
here is a link to the photo of of the multimeter when checking resistance on my newly rebuilt coil.
looks like 22.5k ohms
this is a fully rebuilt coil with new primary wires, copper core spark plug wire and NGK resistor ends
i also measured just a chunk of bare spark plug cable and there was no resistance.   i can't disassemble it or id check the rest of the pieces for you.
Hope this helps
On Jan 23, 2013, at 9:31 AM, eric geiger wrote:
> I just rebuilt 2 coils and checked resistance.   I know both I mine were identical but I can't remember off the top of my head now how much. I have to check my multi meter again and confirm but I can have an answer for you when I head to work tonight on > the coil resistance.   I used copper core wire and the resistor ends that Bruce sells on his website.
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> www.prgnocturne.com
> On Jan 23, 2013, at 9:21 AM, "ronny lucassen" ronnylucassen@...
> > Hello
> > resistance coil?
> > resistance cable?
> > please let me know
> > thanks
> > ronny
