brake bleeding
eric.geiger
brake bleeding
Post by eric.geiger »
what is the proper order for bleeding the brakes on a Z600 coupe.
Driver/pass/front/rear
Don Laughton
Re: brake bleeding
Post by Don Laughton »
Start at the wheel cylinder furthest from the master cylinder (right rear
). Go to the left rear, right front and finally left front. Basically, start at the furthest point and work your way forward. Be sure to hold the pedal down until the bleed screw is closed. Continue to work  each cylinder until the fluid comes out fresh, clear and without bubbles. Good luck Don B. Laughton Sent from my iPhone
Driver/pass/front/rear =
bottom cop
Re: brake bleeding
Post by bottom cop »
Most auto parts stores also carry a relatively cheap kit that allows this process to be done by one person.  Regardless of how you do it, be extremely careful not to allow the master cylinder to run out of fluid in the middle of the process.  That will put air back in the lines and force you to start the entire process over again.  Clean up any spilled brake fluid completely, it is corrosive.  Anyone who is renewing a brake system should consider using silcone brake fluid, it works much better for vehicles that are being dirven infrequently because it does not draw moisture and is non-corrosive to brake parts.
Don Laughton To:
"2cylinderhondas@yahoogroups.com" Sent:
Sunday, June 3, 2012 4:03 PM Subject:
Re: [2cylinderhondas] brake bleeding
