Headliner removal
enerdome
Headliner removal
Post by enerdome »
How difficult is it to remove the front half of the Headdliner in a Z600? there is a dent there that the bodyman missed and needs to be repaired. thanks
Re: Headliner removal
To remove the headliner in a Coupe you will have to remove the windshield and rubber seal in the front.  The rear is held down by three clips, I have used a steel ruler to find them, and then move it to where the ruler is on the clip and push down and it should come off.  If not then use another long screw driver or thin strip of metal to lift the front edge of the clip up and then it will come out.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > enerdome > Sent:
> Friday, March 12, 2010 9:58
> [2cylinderhondas] Headliner removal
> thanks
