I used some rear bushings and brackets from a BMW 3 series, all I had to do was bend the lock tab a little to fit in the upper slot of the frame on my N600. The brackets are cad plated in silver and they look pretty good on the car.
I can provide pictures and part numbers for anyone interested.
Mike
Front sway bar bushings ?
Re: Front sway bar bushings ?
always interested in anything that works...might not use it know but who knows when..
> Mike & Tami Speer
> Sunday, August 02, 2009 6:46
> RE: [2cylinderhondas] Front sway
> bar bushings ?
> I used some
> rear bushings and brackets from a BMW 3 series, all I had to do was bend the > lock tab a little to fit in the upper slot of the frame on my N600. The > brackets are cad plated in silver and they look pretty good on the > car.
> I can provide
> Mike
> [mailto:2cylinderho ndas@yahoogroups .com]
> lt1ski
> Saturday, August 01, 2009 6:12 AM
> [2cylinderhondas]
> Hello , my front sway bar bushing closest to the front bumper are totally > gone , so when driving under load going up hill the whole front ened starts to > shake so bad I have to stop and start up again not good , do I have to make > these myself or can you get them somewhere? thanks dean
> No virus found in this incoming
> message.
> Checked by AVG - www.avg.com
> Version: 8.5.392 / Virus Database:
> 270.13.37/2273 - Release Date: 07/31/09
> 05:58:00
mygto_1999
Hi Tom,
The bracket is part number 33 50 6 779 734 and lists for about $3.04 a piece.
The bushing (For 15mm sway bar) is part number 33 55 1 131 155 and lists for about $8.80 a piece.
Mike
Mike
Yep, other bushings will work, heck, wrap a section of garden water hose and clamp it in place. They too will work. But, they look like other bushings and garden hose. The bushings I provide are 80 shore molded rubber. The look just like the originals, fit like the originals and work great.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Mike & Tami Speer > Sent:
> Tuesday, August 04, 2009
> 8:04 PM
> RE:
> [2cylinderhondas] Front sway bar bushings ?
> Hi
> Tom,
> The bracket is part number 33 50 6 779 734 and lists for about $3.04 a > piece.
> The bushing
> (For 15mm sway bar) is part number 33 55 1 131 155 and lists for about $8.80 a > piece.
> Mike
> TOM
> THIES
> Sunday, August 02, 2009 9:41 PM
> always interested in anything that works...might not use it > know but who knows when..
> > ----- Original Message
> > Mike & Tami Speer
> > PM
> > RE: [2cylinderhondas] Front sway bar bushings
> > I used some
> > rear bushings and brackets from a BMW 3 series, all I had to do was bend the > > lock tab a little to fit in the upper slot of the frame on my N600. The > > brackets are cad plated in silver and they look pretty good on the > > car.
> > I can
> > Mike
> > On Behalf Of
> > lt1ski
> > Hello , my front sway bar bushing closest to the front bumper are totally > > gone , so when driving under load going up hill the whole front ened starts > > to shake so bad I have to stop and start up again not good , do I have to > > make these myself or can you get them somewhere? thanks > > dean
> > message.
> > Database: 270.13.37/2273 - Release Date: 07/31/09
> > 05:58:00
> message.
> 270.13.41/2277 - Release Date: 08/02/09
> 17:56:00
