In need of a cooling fan
geez_tech
Post by geez_tech »
Hi All,
Does anyone here have a good used cooling fan for the engine laying
around?
I found mine to be missing half of a blade.
Mike
scott lesniak
Re: In need of a cooling fan
Post by scott lesniak »
I am sure I do $25 plus shipping
Scott
Tue, 9/2/08, geez_tech
Subject: [2cylinderhondas] In need of a cooling fan
Date: Tuesday, September 2, 2008, 4:39 PM
Hi All,
Does anyone here have a good used cooling fan for the engine laying around?
Mike
doug3742
Post by doug3742 »
--- In 2cylinderhondas@yahoogroups.com, "geez_tech" wrote:
> Hi All,
> around?
> Mike
> Hi Mike You could use A electric fan remove the old fan ,pulley
mount electric fan in its place no belts needed worked for me.You may
gain a little horse power.
Mike and Tami Speer
Post by Mike and Tami Speer »
Thanks Doug,
   That is an interesting idea if I can find one small enough and with a good CFM rating.
Mike
Mike and Tami Speer
Thanks Scott,
  Can you e-mail me a picture of it? Is this just the fan blade or the whole assembly with the housing, bearings, pulley, etc?
The Haynes manual mention that the pulley is a interference fit and you can’t re-use it, but you also can’t get new pulleys anymore. Has anyone else been down this road before with disassembling the fan from the housing and re-using the pulley?
Mike
Kevin Lister
Post by Kevin Lister »
Doug,
What is the electric fan out of? A car? A big bike?
kev
Tue, 9/2/08, Mike and Tami Speer
Subject: RE: [2cylinderhondas] Re: In need of a cooling fan
Date: Tuesday, September 2, 2008, 7:15 PM
Thanks Doug,
Mike
2cylinderhondas@ yahoogroups. com [mailto:2cylinderho ndas@yahoogroups .com] On Behalf Of doug3742 Sent:
Tuesday, September 02, 2008 2:28 PM
> Hi All,
> Does anyone here have a good used cooling fan for the engine laying > around?
> Mike
> Hi Mike You could use A electric fan remove the old fan ,pulley mount electric fan in its place no belts needed worked for me.You may gain a little horse power.
No virus found in this incoming message.
Checked by AVG - http://www.avg. com
Version: 8.0.169 / Virus Database: 270.6.15/1648 - Release Date: 9/2/2008 5:29 PM
Post by Miles »
I used one from a Honda GL1000 about a 1975 Vintage. Bust out the
veins and it bolts right in using it's original sheetmetal housing
parts. I used mine for 20 years, I think I let it go with either
Dinky or my 600 pick up truck.
The GL1000 blade is just the right size. The fan will run either
direction.
P.S. Free Decal for attendees, day of the Meet !
Mike and Tami Speer
Re: In need GL1000 Fan
Post by Miles »
Yes, exactly the one. Just cut off a majority of the sheetmetal until
you have 3 mounting tabs, drill the tabs & housing in 3 places. On
mine, I also cut about 1 1/2" off the housing at the back to give it
a lower profile.
Maybe we can get Betsy H. in Savannah to send a photo, I don't have
one.
Kevin Lister
Miles,
Isn't the GL-1000 the same bike that uses a similar carb rebuild kit for the 600?
kev
Wed, 9/3/08, Miles
Subject: [2cylinderhondas] Re: In need of a cooling fan
Date: Wednesday, September 3, 2008, 8:15 PM
I used one from a Honda GL1000 about a 1975 Vintage. Bust out the veins and it bolts right in using it's original sheetmetal housing parts. I used mine for 20 years, I think I let it go with either Dinky or my 600 pick up truck.
The GL1000 blade is just the right size. The fan will run either direction.
, Kevin Lister
> Doug,
> kev
> --- On Tue, 9/2/08, Mike and Tami Speer wrote:
> From: Mike and Tami Speer
> Subject: RE: [2cylinderhondas] Re: In need of a cooling fan > To:
> Thanks Doug,
> Mike
> From: 2cylinderhondas@ yahoogroups. com [mailto:2cylinderho ndas@yahoogroups .com] On Behalf Of doug3742 > Sent: Tuesday, September 02, 2008 2:28 PM > To: 2cylinderhondas@ yahoogroups. com > Subject: [2cylinderhondas] Re: In need of a cooling fan
> --- In 2cylinderhondas@ yahoogroups. com, "geez_tech" wrote:
> > Hi All,
> > around?
> > Mike
> > Hi Mike You could use A electric fan remove the old fan ,pulley > mount electric fan in its place no belts needed worked for me.You may > gain a little horse power.
> Checked by AVG -
http://www.avg.
com
9/2/2008 5:29 PM
