Oil filter plate (washer)
John
Post by John »
Changed the oil on my 1972 N600 sedan for the first time since I got it and discovered the
plate (washer) was missing. It's that washer that goes between the spring and the rubber
gasket under the oil filter. I haven't yet asked at the Honda dealer for the part (90420-551-
000) but in case it isn't available from them, does anyone know where I can get a suitable
replacement. The hardware store washer has the right OD (29 mm) but the wrong ID (17mm).
I think the washer may be about 28 mm OD and needs to be 18 mm ID, or a hair more. ( I'm
not putting the new filter in until I have something in there to hold that gasket in place.
Re: Oil filter (washer)
Post by Miles »
John,
Alot of cars are missing that washer because it gets stuck to the
rubber seal and people throw it away. There's a similar washer in the
transmission that fits, it's a thrust washer. If you can't order the
washer from Honda, I should have some spares.
John Ph. Graf
Post by John Ph. Graf »
Thanks. I'll call Honda later today or tomorrow morning.
I knew that there was supposed to be a washer there, so I was careful
to account for all the parts when I pulled the filter. I smelled
trouble when I could see that the gasket was squeezed down inside the
spring.
On Aug 6, 2007, at 3:19 AM, Miles wrote:
> John,
Linda Classon
Post by Linda Classon »
Thanks, I'll try Honda and if they can't get me one I'll get back
to you.
Linda
On 6 Aug 2007 at 8:19, Miles wrote:
> John,
John
Post by John »
Called Honda this morning. Parts guy said that the part number for the oil filter washer
(90420-551-000) was still a good number. We'll see when I stop in Thursday morning
when I'm in town. John
> to you.
> Linda
> > John,
> > Miles
> > got it and discovered the plate (washer) was missing. It's that washer that goes
between the
