Looking for door cylinders and hatch cylinder keyed alike for my 72
AN600.
Anybody got any?
David
Door locks / cylinders
Re: Door locks / cylinders
Hi David
Any good locksmith should be able to adapt cylinders
to the same key. I had it done for my 1300 Coupe 9.
Peter
alike for my 72
AN600.
Anybody got any?
David
To
To unsubscribe from this group, send an email to:
2cylinderhondas-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
Find local movie times and trailers on Yahoo! Movies.
http://au.movies.yahoo.com
Peter
alike for my 72
AN600.
Anybody got any?
David
To
Terms of Service.
I am a full time locksmith. I also have a big box full of Honda 600
keys. If you send me your locks I will first see if I have a key that
fits and make you copies. The charge for the first key is $20.00. If I
don't have a key that fits, I will dismantle 1 lock and make a key or
cut one by code, the charge for the first key is $20.00.
If you have 3 mismatched locks, I can repin so they are all the same
(not the ignition) cost is $20.00 per lock + keys. If you ned an
ignition key and have your original manual, look inside the manual and
usually the dealer wrote the key code in it, it's a 4 digit number. I
can cut you a key by code where I work for $20.00.
If you don't have any locks at all, I should be able to round up a set.
