weatherstripping
TOM THIES
Re: weatherstripping
Post by TOM THIES »
Bill and James
Thanks for the info.  Bill I am emailing them for information and trying to get a small piece of material.  I will let all know what happens.  I tried cutting the back side off of the weather stripping to see if that would work and it did except that I still had to close the door hard so it came right back off.  I took it out for a spin yesterday and the rebuilt carb I got on ebay made a huge difference in running.  fixed the ruff idle and up and down running.
thanks all
Tom T
> James
> Hawkins
> Saturday, May 23, 2009 6:38
> Re: [2cylinderhondas]
> weatherstripping
> Tom,   I used the ZX132561U and it's easy to put on and works > good.  I have to slam the door a little harder than with the old > collapsed trim. I didn't worry about the bottom as it was usable.  It > might be tricky down there, price was $34.99 I believe.
> > tdthies1
> > Thursday, May 21, 2009 11:02
> > PM
> > [2cylinderhondas]
> > weatherstripping
> > well i tried the diamond shaped push on and the door wont even close.the > > weatherstripping is ery thick, item No. 132562. MFG part no. uws 1580-25.
> > and know the item picture wont even show up on JC whitney.
> > So can
> > some one give me the item no. for the round push on weatherstripping. ..
> > i have called JC Whitney with NO help at all.
> > Thanks for any
> > help
> > Tom T
> > No virus found in this incoming message.
> > Checked by AVG -
> > www.avg.com
> > Version: 8.5.339 / Virus Database: 270.12.36/2126 - Release > > Date: 05/21/09 06:22:00
Tom T.
    You can move the latch catch on the door post out a bit to allow the door to close easier, this will set the door out a bit but will allow it to close easier.   Then after a while you can move it back and it will close like before.  Slamming your door is never a good thing to do.  Besides causing the door to crack at the window brace (Coupe) it can jar the internal components of the door itself.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > TOM THIES > Sent:
> Saturday, May 23, 2009 9:38
> [2cylinderhondas] weatherstripping
> Bill and James
> Thanks for the info.  Bill I am emailing them for information and > trying to get a small piece of material.  I will let all know what > happens.  I tried cutting the back side off of the weather stripping to > see if that would work and it did except that I still had to close the > door  hard so it came right back off.  I took it out for a spin > yesterday and the rebuilt carb I got on ebay made a huge difference in > running.  fixed the ruff idle and up and down running.
> thanks all
> Tom T
> > James
> > Hawkins
> > AM
> > weatherstripping
> > Tom,   I used the ZX132561U and it's easy to put on and works > > good.  I have to slam the door a little harder than with the old > > collapsed trim. I didn't worry about the bottom as it was usable.  It > > might be tricky down there, price was $34.99 I > > believe.
> > > tdthies1
> > > Sent:
> > > PM
> > > [2cylinderhondas]
> > > weatherstripping
> > > well i tried the diamond shaped push on and the door wont even > > > close.the weatherstripping is ery thick, item No. 132562. MFG part no. uws > > > 1580-25. and know the item picture wont even show up on JC whitney.
> > > So can some one give me the item no. for the round push on > > > weatherstripping. .. i have called JC Whitney with NO help at > > > all.
> > > Thanks for any help
> > > Tom T
> > > Checked by AVG -
> > > www.avg.com
> > > Release Date: 05/21/09 06:22:00
