carb gaskets
riccysmith
carb gaskets
Post by riccysmith »
Who can I go to for basic carb gaskets like float bowl cover, accel
pump, etc? Primarily just the paper and rubber parts, not hard
parts. thx. ric.
Re: carb gaskets
Which carb are you dealing with, early or later..
a65tigrr
Re: carb gaskets
Post by a65tigrr »
For the early style carb with the vacuum diaphram, You can buy a carb kit for a Honda CVCC Kiehin 3 bbl. It has the same accelerator pump, and o-rings you can use. I think I even used the needle valve. I reused my float bowl gasket, put it in hot water to rejuvinate it a little bit.
Greg
riccysmith wrote:
> Who can I go to for basic carb gaskets like float bowl cover, accel > pump, etc? Primarily just the paper and rubber parts, not hard > parts. thx. ric.
> Your use of Yahoo! Groups is subject to the
> Yahoo! Terms of Service
Do you Yahoo!?
Free
online calendar
with sync to Outlook(TM).
Re: carb gaskets
Hi Greg;
    Do you still have the part number?
> Greg Sikes
> Saturday, June 07, 2003 3:27
> Re: [2cylinderhondas] carb
> gaskets
> For the early style carb with the vacuum diaphram, You can buy a carb kit > for a Honda CVCC Kiehin 3 bbl. It has the same accelerator pump, > and o-rings you can use. I think I even used the needle valve. I reused > my float bowl gasket, put it in hot water to rejuvinate it a little bit.
> Greg
> riccysmith ricsmith@...
> > Who
> > can I go to for basic carb gaskets like float bowl cover, accel > > pump, > > etc? Primarily just the paper and rubber parts, not hard > > parts. thx.
> > ric.
> > to:
> > Your
> Do you Yahoo!?
> Free
> online
> calendar
> To
> to:
> Your
a65tigrr
Re: carb gaskets
Post by a65tigrr »
Bill,
Here is a scan of the package, I bought it at Roy Rogers foriegn car parts. I have overhauled two carbs using these kits.
Greg william colford wrote:
> Hi Greg;
> > Greg Sikes
> > Saturday, June 07, 2003 3:27 AM
> > Re: [2cylinderhondas] carb gaskets
> > Greg
> > riccysmith > ricsmith@...
> > > Who can I go to for basic carb gaskets like float bowl cover, accel > > > pump, etc? Primarily just the paper and rubber parts, not hard > > > parts. thx. ric.
> > Do you Yahoo!?
> > Free
> > online calendar
Do you Yahoo!?
Free online calendar with sync to Outlook(TM).
