Hi folks.
Has anyone recently put in a new radio/tape deck into an N600? I can't
find something that is small enough to fit without having to cut the dash
opening, which I don't want to do. Just curious as it's an odd size and
everything I've seen so far does not work.
Let me know if you have insights to:
dstark@...
Thanks!
Doug
Douglas Stark
STARK CONSULTANTS, INC.
One Memorial Square, Whitinsville, MA 01588
http://www.starkconsult.com XXX-XXX-XXXX
Radio for N600 Sedan
Re: Radio for N600 Sedan
--- In 2cylinderhondas@yahoogroups.com, "Doug Stark[Stark
Consultants]" wrote:
fit. I found one at a place called discount auto parts, and it was
only 30 bucks. It was tight, but it did fit without cutting more
than the original cut-out provides. I hope this helps you, and I
will send a pic to you if you need it.
Nick
If you really look, you can find a cheap cassette deck that will> Hi folks.
> dstark@s...
> Thanks!
> Doug
Nick
> Douglas Stark
