THIS @#$\%^&*()+ bolt I can'tget at it!!
Is there a mystery tool,or trick to getting a wrench on that 12mm
clutch arm adjusting bolt? I tried many ideas,such as using a
shorter bolt or a sedan 10mm head seat bolt!
Re: THIS @#$\%^&*()+ bolt I can'tget at it!!
Not to give away any secrets, but a 12 point box end 12mm wrench is what I
use. Although I have worked on 600's that had a hole drilled into the body
to allow a wrench to fit through. Worked real well, it also had a rubber
plug in it to keep it clean.
Post by Steve »
That bolt in the clutch arm is hardened steel, I don't reccommend
putting another in it's place. If you remove the heater blower it is
very easy to adjust the clutch from the top.
what I
the body
rubber
> From: "riceburner006"
> Sent: Saturday, November 30, 2002 12:07 AM
> Subject: [2cylinderhondas] THIS @#$%^&*()+ bolt I can'tget at it!!
> > 2cylinderhondas-unsubscribe@y...
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
