gas milage??
iluv4ds
gas milage??
Post by iluv4ds »
MY Z600 MUST NEED SOME CARB WORK CAUSE I GOT CLOSE TO 40 MPG ALL
SUMMER, AND EVERYBODY THOUGHT IT PROBABLY GOT 100MPG, CAUSE IT WAS SO
SMALL.
ANYBODY GOT A SPARE RR WINDOW FOR A 600 SEDAN. A HUNTER SHOT MINE
OUT. I PARKED IT NEXT TO MY SAMARI, AND THEY ARE BOTH THE SAME
EXTERNAL LENGTH, AND THE WHEELBASE IS ALSO THE SAME 80 INCHES. WONDER
IF THE 600 SEDAN BODY WOULD SET DOWN OVER THE SAMARI CHASSIS????? THE
BOLT PATTERN ON THE SAMARI IS THE SAME AS A FORD PICKKUP. IVE GOT
SOME OLD ALUMINUM CENTERLINE 10INCH WHEELS LEFT OVER FROM A MINI-
SPRINT I HAD. IF THEY WOULD FIT OVER THE DISCS AND DRUMS, MIGHT NOT
HAVE TO MODIFY THE HONDA WHEELWELLS. JUST DREAMIN OUT LOUD....
JUNKMAN/ALLIANCE, NEBR.
alarconlujan
Re: gas milage??
Post by alarconlujan »
I WOULD LIKE TO KNOW ABOUT THE CENTERLINE WHEELS,  DO THE BOLT PATTERNS WORK FOR THE HONDA 600 ?
I AM LOOKING FOR A WAY TO SAVE SOME MONEY ON WHEELS TO SHARPEN UP THE CAR?
HAROLD
> iluv4ds
> [mailto:JUNKMAN@...]
> Wednesday, March 06, 2002 6:14
> [2cylinderhondas] gas milage??
> SMALL.
> FROM A MINI-
> MIGHT NOT
> LOUD....
> To
> unsubscribe from this group, send an email
> to:
> Your
> Yahoo! Terms of Service
aahondaowner
Re: gas milage??
Post by aahondaowner »
HAROLD,
    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
> Harold Hong
> Wednesday, March 06, 2002 7:42
> RE: [2cylinderhondas] gas
> milage??
> I
> WOULD LIKE TO KNOW ABOUT THE CENTERLINE WHEELS,  DO THE BOLT PATTERNS > WORK FOR THE HONDA 600 ?
> I AM
> LOOKING FOR A WAY TO SAVE SOME MONEY ON WHEELS TO SHARPEN UP THE > CAR?
> HAROLD
> > iluv4ds [
> > mailto:JUNKMAN@...
> > Wednesday, March 06, 2002 6:14 PM
> > MY Z600 MUST NEED
> > SMALL.
> > ANYBODY GOT A
> > OUT. I PARKED IT
> > To
> > to:
> > Your
> To
> to:
> Your
alarconlujan
Re: gas milage??
I FOUND TWO MINI CART RACING WHEELS WHERE THE PATTERN IS SLIGHTLY SMALLER THAN THE 600,  MY FRIEND SAYS WITH FILING THE HOLES TO ELONG IT OUT TO REACH THE LARGER PATTERN, AND IT SHOULD BE FIND, AS LONG AS I FILE IT PERFECT , SO THE WHEEL IS STILL PERFECT ROUND , AND NOT HAVE THE WHEEL GO OFF SET.  WHAT DO YOU THINKS
HAROLD
> junkman
> Wednesday, March 06, 2002 6:58
> HAROLD,
>      I TRIED
> THEM ON THE 600, BUT WONT FIT. THEY ARE THE SAME AS A GOLF CART, OR SMALL > TRAILER. MIGHT CHECK OUT USED MINI-SPRINT PARTS, OR EVEN NEW WHEELS, CAUSE > THEY MAKE ALL SORTS, AND USED, THEY ARE CHEAP... YOU MIGHT SEE IF YOU COULD > DRILL ANOTHER BOLT PATTERN IN BETWEEN THE HONDAS. CANT REMEMBER IF THE FLANGE > IS ROUND SO YOU COULD DRILL INBETWEEN THE STUDS, OR IF ITS CUT BACK, WHICH > WONT ALLOW DRILLING. I SAW AN ADD ON 55-56-57 CHEVYS LAST WEEK FOR WHEEL > ADAPTERS FOR ANYTHING, BUT DELETED IT, SO CANT HELP YOU THERE EITHER. IF YOU > USE AN ADAPTER, IT SPACES THE WHEELS OUT THE THICKNESS OF THE ADAPTER AND YOU > DONT WANT THE WHEELS HANGIN WAY OUT THERE CAUSE IT CAUSES EXCESSIVE BEARING > WEAR AND UP FRONT, MAKES IT HARD TO STEER BECAUSE THEY DESIGN THE FRONT END SO > THE CENTER OF THE TIRE PRINT IS THE PIVOT POINT. HOPE I DIDNT LOOSE YOU IN THE > EXPLANIATION. IAM NO EXPERT, JUST KNOW WHAT I LEARNED ON MY > OWN...JUNKMAN/ALLIANCE, NEBR.
> > Harold Hong
> > PM
> > milage??
> > I
> > WOULD LIKE TO KNOW ABOUT THE CENTERLINE WHEELS,  DO THE BOLT PATTERNS > > WORK FOR THE HONDA 600 ?
> > I
> > AM LOOKING FOR A WAY TO SAVE SOME MONEY ON WHEELS TO SHARPEN UP THE > > CAR?
> > HAROLD
> > > iluv4ds [
> > > mailto:JUNKMAN@...
> > > Sent:
> > > MY Z600 MUST NEED
> > > SMALL.
> > > ANYBODY GOT
> > > A SPARE RR WINDOW FOR A 600 SEDAN. A HUNTER SHOT MINE > > > OUT. I PARKED IT > > > NEXT TO MY SAMARI, AND THEY ARE BOTH THE SAME > > > EXTERNAL LENGTH, AND THE > > > WHEELBASE IS ALSO THE SAME 80 INCHES. WONDER > > > IF THE 600 SEDAN BODY > > > WOULD SET DOWN OVER THE SAMARI CHASSIS????? THE > > > BOLT PATTERN ON THE > > > SAMARI IS THE SAME AS A FORD PICKKUP. IVE GOT > > > SOME OLD ALUMINUM > > > CENTERLINE 10INCH WHEELS LEFT OVER FROM A MINI- > > > SPRINT I HAD. IF THEY > > > WOULD FIT OVER THE DISCS AND DRUMS, MIGHT NOT > > > HAVE TO MODIFY THE HONDA > > > WHEELWELLS. JUST DREAMIN OUT LOUD....
> > > To unsubscribe from this group, send an email
> > > to:
> > > Your
> > to:
> > Your
> To
> to:
> Your
aahondaowner
Re: gas milage??
HAROLD,
     IF THE CENTER OF THE WHEEL FITS ON THE HUB REALLY TIGHT, YOU MIGHT GET AWAY WITH FILING THE LUG NUT HOLES ENOUGH TO FIT, BUT IF IT ISNT, YOULL PROBABLY SCREW UP A GOOD SET OF WHEELS. IF YOU DONT HAVE MUCH IN THEM,,, WHAT THE HECK, TAKE A CHANCE...JUNKMAN
> Harold Hong
> Wednesday, March 06, 2002 9:03
> milage??
> I
> FOUND TWO MINI CART RACING WHEELS WHERE THE PATTERN IS SLIGHTLY SMALLER THAN > THE 600,  MY FRIEND SAYS WITH FILING THE HOLES TO ELONG IT OUT TO REACH > THE LARGER PATTERN, AND IT SHOULD BE FIND, AS LONG AS I FILE IT PERFECT , SO > THE WHEEL IS STILL PERFECT ROUND , AND NOT HAVE THE WHEEL GO OFF SET.
> WHAT DO YOU THINKS
> HAROLD
> > junkman
> > PM
> > Re:
> > HAROLD,
> >      I TRIED
> > THEM ON THE 600, BUT WONT FIT. THEY ARE THE SAME AS A GOLF CART, OR SMALL > > TRAILER. MIGHT CHECK OUT USED MINI-SPRINT PARTS, OR EVEN NEW WHEELS, CAUSE > > THEY MAKE ALL SORTS, AND USED, THEY ARE CHEAP... YOU MIGHT SEE IF YOU COULD > > DRILL ANOTHER BOLT PATTERN IN BETWEEN THE HONDAS. CANT REMEMBER IF THE > > FLANGE IS ROUND SO YOU COULD DRILL INBETWEEN THE STUDS, OR IF ITS CUT BACK, > > WHICH WONT ALLOW DRILLING. I SAW AN ADD ON 55-56-57 CHEVYS LAST WEEK FOR > > WHEEL ADAPTERS FOR ANYTHING, BUT DELETED IT, SO CANT HELP YOU THERE EITHER.
> > IF YOU USE AN ADAPTER, IT SPACES THE WHEELS OUT THE THICKNESS OF THE ADAPTER > > AND YOU DONT WANT THE WHEELS HANGIN WAY OUT THERE CAUSE IT CAUSES EXCESSIVE > > BEARING WEAR AND UP FRONT, MAKES IT HARD TO STEER BECAUSE THEY DESIGN THE > > FRONT END SO THE CENTER OF THE TIRE PRINT IS THE PIVOT POINT. HOPE I DIDNT > > LOOSE YOU IN THE EXPLANIATION. IAM NO EXPERT, JUST KNOW WHAT I LEARNED ON MY > > OWN...JUNKMAN/ALLIANCE, NEBR.
> > > Harold Hong
> > > Sent:
> > > PM
> > > milage??
> > > WHEELS,  DO THE BOLT PATTERNS WORK FOR THE HONDA 600 > > > ?
> > > HAROLD
> > > > From:
> > > > iluv4ds [
> > > > mailto:JUNKMAN@...
> > > > Sent:
> > > > To:
> > > > Subject:
> > > > MY Z600 MUST NEED
> > > > SOME CARB WORK CAUSE I GOT CLOSE TO 40 MPG ALL > > > > SUMMER, AND EVERYBODY > > > > THOUGHT IT PROBABLY GOT 100MPG, CAUSE IT WAS SO > > > > SMALL.
> > > > ANYBODY
> > > > GOT A SPARE RR WINDOW FOR A 600 SEDAN. A HUNTER SHOT MINE > > > > OUT. I > > > > PARKED IT NEXT TO MY SAMARI, AND THEY ARE BOTH THE SAME > > > > EXTERNAL > > > > LENGTH, AND THE WHEELBASE IS ALSO THE SAME 80 INCHES. WONDER > > > > IF THE > > > > 600 SEDAN BODY WOULD SET DOWN OVER THE SAMARI CHASSIS????? THE > > > > BOLT > > > > PATTERN ON THE SAMARI IS THE SAME AS A FORD PICKKUP. IVE GOT > > > > SOME > > > > OLD ALUMINUM CENTERLINE 10INCH WHEELS LEFT OVER FROM A MINI- > > > > SPRINT I > > > > HAD. IF THEY WOULD FIT OVER THE DISCS AND DRUMS, MIGHT NOT > > > > HAVE TO > > > > MODIFY THE HONDA WHEELWELLS. JUST DREAMIN OUT > > > > LOUD....
> > > > To
> > > > to:
> > > > Your
> > > > Yahoo! Terms of
> > > > Service
> > > to:
> > > Your
> > to:
> > Your
> to:
> Your
timk11
Honda 600 Bolt Pattern
Post by timk11 »
The bolt pattern of the Honda 600 is 110mm, this is measured
diagonally from the center of the studs. The only other car with the
same pattern, to the best of my knowledge, is Mazda, like the RX7.
Some ATV's such as the Honda ATC 185 has the same pattern as well. I
once installed 9" ATV aluminums on my Dinky convertible, but I had to
install 3" spacers so they would clear the brakes. Filing or
enlongating the holes as well as bending the studs to fit is not
reccommended.
SMALLER
TO REACH
PERFECT , SO
SET. WHAT
> DO YOU THINKS
> HAROLD
> From: junkman [mailto:JUNKMAN@B...]
> Sent: Wednesday, March 06, 2002 6:58 PM
> To: 2cylinderhondas@y...
> Subject: Re: [2cylinderhondas] gas milage??
> HAROLD,
A GOLF
EVEN NEW
> WHEELS, 'CAUSE THEY MAKE ALL SORTS, AND USED, THEY ARE CHEAP... YOU
MIGHT SEE
REMEMBER
IF ITS CUT
LAST WEEK
THERE
THICKNESS OF THE
CAUSES
THEY
POINT.
KNOW WHAT I
> From: Harold Hong
> Sent: Wednesday, March 06, 2002 7:42 PM
> Subject: RE: [2cylinderhondas] gas milage??
PATTERNS
UP THE
> CAR?
> HAROLD
> From: iluv4ds [mailto:JUNKMAN@B...]
> Sent: Wednesday, March 06, 2002 6:14 PM
> Subject: [2cylinderhondas] gas milage??
ALL
IT WAS SO
> SMALL.
MINE
INCHES. WONDER
CHASSIS????? THE
GOT
MINI-
MIGHT NOT
> 2cylinderhondas-unsubscribe@y...
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Service.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
Service.
fourmusicians93063
Re: gas milage??
Post by fourmusicians93063 »
Harold,
I strongly sugest getting used rims and sandblasting them then painting them black or silver.
Do not waste your time tinkering with those wheel s you mentioned it's just a hassel and a waste of time
Jamie
>From: "junkman"
>Reply-To: 2cylinderhondas@yahoogroups.com
>To:
>Date: Wed, 6 Mar 2002 23:08:14 -0700
>HAROLD,
> From: Harold Hong
> Sent: Wednesday, March 06, 2002 9:03 PM
> HAROLD
> From: junkman [mailto:JUNKMAN@...]
> HAROLD,
> From: Harold Hong
> HAROLD
> From: iluv4ds [mailto:JUNKMAN@...]
> SMALL.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Join the world�s largest e-mail service with MSN Hotmail. Click Here
alarconlujan
Re: gas milage??
MY FRIEND PURCHASED THE RESTORED BLUE Z COUPE FROM EBAY THAT WAS ASKING FOR 9,000.00
BUT PURCHASED IT CHEAPER, DIRECT,    THIS BLUE BEAUTY IS PRETTY NICE, I WENT TO SEE IT AND IT HAD CHROME Z COUPE WHEELS, WHICH I WOULD LIKE TO DO THAT,  IT IS SHARP!
HAROLD
> Jamie St. Louis
> [mailto:lookn4u2return@...]
> Thursday, March 07, 2002
> 11:12 AM
> Harold,
> I strongly sugest getting used rims and sandblasting them then painting > them black or silver.
> Do not waste your time tinkering with those wheel s you mentioned it's just > a hassel and a waste of time
> Jamie
> >From: "junkman"
> >To:
> >HAROLD,
> > IF THE CENTER OF THE WHEEL FITS ON THE HUB REALLY TIGHT, YOU > MIGHT GET AWAY WITH FILING THE LUG NUT HOLES ENOUGH TO FIT, BUT IF IT ISNT, > YOULL PROBABLY SCREW UP A GOOD SET OF WHEELS. IF YOU DONT HAVE MUCH IN THEM,,, > WHAT THE HECK, TAKE A CHANCE...JUNKMAN
> > From: Harold Hong
> > I FOUND TWO MINI CART RACING WHEELS WHERE THE PATTERN IS > SLIGHTLY SMALLER THAN THE 600, MY FRIEND SAYS WITH FILING THE HOLES TO ELONG > IT OUT TO REACH THE LARGER PATTERN, AND IT SHOULD BE FIND, AS LONG AS I FILE > IT PERFECT , SO THE WHEEL IS STILL PERFECT ROUND , AND NOT HAVE THE WHEEL GO > OFF SET. WHAT DO YOU THINKS
> > HAROLD
> > HAROLD,
> > I TRIED THEM ON THE 600, BUT WONT FIT. THEY ARE THE SAME AS A > GOLF CART, OR SMALL TRAILER. MIGHT CHECK OUT USED MINI-SPRINT PARTS, OR EVEN > NEW WHEELS, CAUSE THEY MAKE ALL SORTS, AND USED, THEY ARE CHEAP... YOU MIGHT > SEE IF YOU COULD DRILL ANOTHER BOLT PATTERN IN BETWEEN THE HONDAS. CANT > REMEMBER IF THE FLANGE IS ROUND SO YOU COULD DRILL INBETWEEN THE STUDS, OR IF > ITS CUT BACK, WHICH WONT ALLOW DRILLING. I SAW AN ADD ON 55-56-57 CHEVYS LAST > WEEK FOR WHEEL ADAPTERS FOR ANYTHING, BUT DELETED IT, SO CANT HELP YOU THERE > EITHER. IF YOU USE AN ADAPTER, IT SPACES THE WHEELS OUT THE THICKNESS OF THE > ADAPTER AND YOU DONT WANT THE WHEELS HANGIN WAY OUT THERE CAUSE IT CAUSES > EXCESSIVE BEARING WEAR AND UP FRONT, MAKES IT HARD TO STEER BECAUSE THEY > DESIGN THE FRONT END SO THE CENTER OF THE TIRE PRINT IS THE PIVOT POINT. HOPE > I DIDNT LOOSE YOU IN THE EXPLANIATION. IAM NO EXPERT, JUST KNOW WHAT I LEARNED > ON MY OWN...JUNKMAN/ALLIANCE, NEBR.
> > From: Harold Hong
> > I WOULD LIKE TO KNOW ABOUT THE CENTERLINE WHEELS, DO THE BOLT > PATTERNS WORK FOR THE HONDA 600 ?
> > I AM LOOKING FOR A WAY TO SAVE SOME MONEY ON WHEELS TO SHARPEN > UP THE CAR?
> > HAROLD
> > MY Z600 MUST NEED SOME CARB WORK CAUSE I GOT CLOSE TO 40 MPG > ALL
> > SUMMER, AND EVERYBODY THOUGHT IT PROBABLY GOT 100MPG, CAUSE IT > WAS SO
> > SMALL.
> > ANYBODY GOT A SPARE RR WINDOW FOR A 600 SEDAN. A HUNTER SHOT > MINE
> WONDER
> CHASSIS????? THE
> > BOLT PATTERN ON THE SAMARI IS THE SAME AS A FORD PICKKUP. IVE > GOT
> > SOME OLD ALUMINUM CENTERLINE 10INCH WHEELS LEFT OVER FROM A > MINI-
> > SPRINT I HAD. IF THEY WOULD FIT OVER THE DISCS AND DRUMS, > MIGHT NOT
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service.
> Join the world’s largest e-mail service with MSN Hotmail.
> Click Here
> To
> to:
> Your
fourmusicians93063
Re: gas milage??
Hi Harold if you get photos put them on the web or send them to me
I would love to see it
what kind of honda do you have
I have a rusty red 70 n 600
Jamie
>From: "Harold Hong"
>To:
>Date: Thu, 7 Mar 2002 13:35:19 -0800
>9,000.00
>IT IS SHARP!
>HAROLD
> From: Jamie St. Louis [mailto:lookn4u2return@...]
> Sent: Thursday, March 07, 2002 11:12 AM
> Harold,
> Jamie
> >From: "junkman"
> >To:
> >HAROLD,
> > From: Harold Hong
> > HAROLD
> > HAROLD,
> > From: Harold Hong
>CAR?
> > HAROLD
> > SMALL.
> ADVERTISEMENT
Chat with friends online, try MSN Messenger: Click Here
aahondaowner
Re: gas milage??
Hi Harold, the RX7 1986 or 87 rim has the same bolt pattern, 110mm
then use a 50 series tire. The RX7 used a 13inch rim 6inches wide.
What you gain in looks you lose in quickness. Send your e-mail
address and I will send pictures.
PATTERNS WORK
> FOR THE HONDA 600 ?
THE CAR?
> HAROLD
WAS SO
> SMALL.
WONDER
THE
NOT
> ADVERTISEMENT
Service.
