Removing Engine Shroud - Tach side
bobs600honda
Post by bobs600honda »
I am in the process of removing both shoulds to better visually see where oil leaks may be coming from.  Battery side is no problem.  Other side, however, the tach cable is in the way of the bolt.
My question is: Do I need to first remove the tach cable (and if so, what do I need to unbolt?  I am hoping to not have to remove the cam holder!).
Thanks for any info.
Bob
Re: Removing Engine Shroud - Tach side
Post by Eric Geiger »
u can remove the tach cable by loosening the little 8mm bolt and just pulling it out
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
On Jan 12, 2014, at 12:07 PM, I am in the process of removing both shoulds to better visually see where oil leaks may be coming from.  Battery side is no problem.  Other side, however, the tach cable is in the way of the bolt.
> Bob
i should have been more specific,  the little bolt on the side of the tach cable housing off the side of the cam housing.   u don't have to remove the whole assembly, just the bolt,  theres a rubber o ring on the tach cable that depending on its age will make it more or less snug so u might have to give it a tug to pull the cable out.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX
>  phone
> XXX-XXX-XXXX
>  fax
> XXX-XXX-XXXX
>  mobile
> egeiger@...
> www.prgnocturne.com
> On Jan 12, 2014, at 12:07 PM, rjamesblues@...
>   rjamesblues@...
> > Bob
bobs600honda
thanks eric.  i will give that a try.
bobs600honda
Hmmm, no O ring.  Perhaps this is contributing to oil leak.  Anyone know where I can get a new one?
Bob
after looking at the manual the tach cable itself doesn't show a o-ring.  even though looking at photos i see one.
there is though on the tach drive an oil seal which is available from
honda600carparts.com .  i can't remember how u have to further disassemble the tach drive to reach it though.
hope this helps. look on page 1-8 of the coupe parts manual for more info.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
On Jan 13, 2014, at 7:49 AM, Hmmm, no O ring.  Perhaps this is contributing to oil leak.  Anyone know where I can get a new one?
> Bob
Robert James
Post by Robert James »
Thanks!
On Mon, Jan 13, 2014 at 5:58 AM, Eric Geiger
> after looking at the manual the tach cable itself doesn't show a o-ring. �even though looking at photos i see one.
> . �i can't remember how u have to further disassemble the tach drive to reach it though.
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX
> �phone
> XXX-XXX-XXXX
> �fax
> XXX-XXX-XXXX
> �mobile
> egeiger@...
> www.prgnocturne.com
> On Jan 13, 2014, at 7:49 AM, rjamesblues@...
> � rjamesblues@...
> > Hmmm, no O ring. �Perhaps this is contributing to oil leak. �Anyone know where I can get a new one?
> > Bob
Robert James
Good morning Eric. �You said you can see the o-ring in pictures? �Are these pics in the manual? �I would certainly like to see!
Thanks for any info!
Bob
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX
> �phone
> XXX-XXX-XXXX
> �fax
> XXX-XXX-XXXX
> �mobile
> egeiger@...
> www.prgnocturne.com
> � rjamesblues@...
> > Bob
i sent you a direct email with some pics
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
On Jan 19, 2014, at 10:48 AM, Robert James wrote:
> Good morning Eric.  You said you can see the o-ring in pictures?  Are these pics in the manual?  I would certainly like to see!
> Bob
> egeiger@...
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX
> >  phone
> > XXX-XXX-XXXX
> >  fax
> > XXX-XXX-XXXX
> >  mobile
> > egeiger@...
> > www.prgnocturne.com
> > On Jan 13, 2014, at 7:49 AM, > rjamesblues@...
> >   > rjamesblues@...
> > > Bob
