Harley carb
r savard
Harley carb
Post by r savard »
Greetings<  Trying the harley carb on my 600. Is the fuel pressure to high off the pump? Fuel pours out? Any ideas?
mygto_1999
Re: Harley carb
Post by mygto_1999 »
Hi, We used these carbs on our sons Jr Dragster (33mm,40mm and 42mm) and saw many needles not seat properly. Make sure the seat is clean and if in doubt replace the needle and seat. Which of the Harley carbs is it? Before we got of racing I was thinking of trying the 33mm carb on my 600.
Mike
Re: Harley carb
I too have been looking for an alternative to the Honda 600 carbs.  Even looking into small engine diaphragm carbs with constant flow coupled to a custom intake manifold.  But here again, there are complications and costs.
While original Honda carbs are still repairable and work well costing far less than custom ideas.
As to the Harley carb, as Mike said it sounds like a needle valve problem allowing the fuel to keep coming in even when the floats are maxed out.
> Mike & Tami
> Speer
> Saturday, May 26, 2012 7:46 AM
> RE: [anzhonda600owners]
> Harley carb
> Hi,
> We used these
> carbs on our sons Jr Dragster (33mm,40mm and 42mm) and saw many needles not > seat properly. Make sure the seat is clean and if in doubt replace the needle > and seat. Which of the Harley carbs is it? Before we got of racing I was > thinking of trying the 33mm carb on my 600.
> Mike
> r
> savard
> Saturday, May 26, 2012 4:47 AM
> [anzhonda600owners]
> Harley carb
> Greetings  Trying the harley carb on my 600. Is the fuel
> ideas?
John Mills
Re: Harley carb
Post by John Mills »
I have used the HD carb with great sucess. You need to get the carb as level to the world as possible
r savard
Re: Harley carb
Post by r savard »
When I feed the carb off a "nurse tank" it runs great. It is a 40mm harley CV carb that I can use the even cruise control linkage on. I will get it flat as possible and start there.
Thanks to all!
> "jbmkwaj@..."
> Saturday, May 26, 2012 1:36 PM
> Re: [anzhonda600owners] Harley carb
> From: billmyong
> To: anzhonda600owners
> Sent: Sat, May 26, 2012 9:15 am
> Subject: RE: [anzhonda600owners] Harley carb
> I too have been looking for an alternative to the Honda 600 carbs.  Even looking into small engine diaphragm carbs with constant flow coupled to a custom intake manifold.  But here again, there are complications and costs.   While original Honda carbs are still repairable and work well costing far less than custom ideas.
> > On Behalf Of
> > Mike & Tami Speer
> > Hi,
> > Mike
> > On Behalf Of
> > r savard
> > Greetings >  Trying the harley carb on my 600. Is the fuel pressure to high off the pump? Fuel pours out? Any ideas?
> > Thanks,
John Mills
Re: Harley carb
yep, same thing I used -- I modified the throttle cable bracket just slightly, and had to grind the choke cable ball to be a bit smaller. then made a short adapter from 3/4 inch exhaust to attach carb to the stock intake. I was then able to use the stock air cleaner box. Mine all looked factory when done.
r savard
Re: Harley carb
Post by r savard »
leveling the carb worked on the overflow problem! Now just adjusting idle and fuel mixture. Is anybody using premium fuel?
Thanks for help...
> "jbmkwaj@..."
> Saturday, May 26, 2012 11:13 PM
> From: r savard
> Sent: Sat, May 26, 2012 4:18 pm
> Subject: Re: [anzhonda600owners] Harley carb
> Thanks to all!
> > jbmkwaj@...
> > " > jbmkwaj@...
> > From: billmyong > billmyong@...
> > To: anzhonda600owners > anzhonda600owners@yahoogroups.com
> > > On Behalf Of
> > > Mike & Tami Speer
> > > Sent:
> > > Hi,
> > > Mike
> > > On Behalf Of
> > > r savard
> > > Sent:
> > > Greetings > >  Trying the harley carb on my 600. Is the fuel pressure to high off the pump? Fuel pours out? Any ideas?
> > > Thanks,
TOM THIES
Re: Harley carb
Post by TOM THIES »
I use premium fuel.  seems so run better for me.
Tom
> r savard
> Tuesday, June 05, 2012 4:49
> carb
> leveling the carb worked on the overflow problem! Now just > adjusting idle and fuel mixture. Is anybody using premium fuel?
> Thanks for help...
> > jbmkwaj@...
> > " > jbmkwaj@...
> > Saturday, May 26,
> > 2012 11:13 PM
> > Re:
> > modified the throttle cable bracket just slightly, and had to grind the > > choke cable ball to be a bit smaller. then made a short adapter from 3/4 > > inch exhaust to attach carb to the stock intake. I was then able to use the > > stock air cleaner box. Mine all looked factory when > > done.
> > From: r savard
> > pm
> > When I feed the carb off a "nurse tank" it runs great. It is a > > 40mm harley CV carb that I can use the even cruise control linkage on. I > > will get it flat as possible and start there.
> > Thanks to all!
> > > jbmkwaj@...
> > > " > > jbmkwaj@...
> > > Sent:
> > > Saturday, May 26,
> > > 2012 1:36 PM
> > > Re:
> > > great sucess. You need to get the carb as level to the world as > > > possible
> > > billmyong > > billmyong@...
> > > anzhonda600owners > > anzhonda600owners@yahoogroups.com
> > > Sent:
> > > carb
> > > I too have been looking for an alternative to the Honda 600 > > > carbs.  Even looking into small engine diaphragm carbs with constant > > > flow coupled to a custom intake manifold.  But here again, there are > > > complications and costs.   While original Honda carbs are still > > > repairable and work well costing far less than custom ideas.
> > > sounds like a needle valve problem allowing the fuel to keep coming > > > in even when the floats are maxed out.
> > > Bill
> > > > From:
> > > > On
> > > > Behalf Of
> > > > Mike & Tami Speer
> > > > Sent:
> > > > Saturday, May 26,
> > > > 2012 7:46 AM
> > > > To:
> > > > Subject:
> > > > carb
> > > > Hi,
> > > > Which of the Harley carbs is it? Before we got of racing I was thinking > > > > of trying the 33mm carb on my 600.
> > > > Mike
> > > > From:
> > > > On Behalf Of
> > > > r savard
> > > > Sent:
> > > > AM
> > > > To:
> > > > Subject:
> > > > Greetings > > >  Trying the harley carb on my 600. Is the fuel
> > > > pressure to high off the pump? Fuel pours out? Any > > > > ideas?
> > > > Thanks,
r savard
Re: Harley carb
Post by r savard »
Harley carb works great!
$140 bucks....
Thanks to all!
> r savard
> "anzhonda600owners@yahoogroups.com"
> Saturday, May 26, 2012 6:18 PM
> Thanks to all!
> > "jbmkwaj@..."
> > From: billmyong
> > > On Behalf Of
> > > Mike & Tami Speer
> > > Sent:
> > > Hi,
> > > Mike
> > > On Behalf Of
> > > r savard
> > > Sent:
> > > Thanks,
