I thought I would go through my Coupe a bit and check gaps and such. I started with the points gap. I set it to .35mm as it seemed a bit small, though I couldn't detect a problem while driving it. My concern now is this: I ran the car a bit with the cover off "just to see" and noticed that the end of the camshaft floats in and out. Please look at the video; is this excessive? Note that I have a sedan engine in the car; maybe the tach setup at the other end would prevent the movement to some extent.
http://www.youtube.com/watch?v=cJPOffE2Tbg
points and camshafts
Re: points and camshafts
Hi Steve, the cam shaft end play should be (.004" to .014").
Yours looks to be alot more than the max.
Probably the cam shaft has worn the holders a little, allowing more end movement. Not sure how the sedan cam holder looks.
If I remember correct the camshaft end controls movement on the tach side, not the gear. On the distibutor side the 3rd diameter (largest) controls movement. Probably could shim the cam holders or use thinner gaskets.
See what the Honda experts say.
Hey it sounds like it's running good!
> Steve
Steve;
Lyle said it, the gasket can change the gap. When I was looking for the correct width of gasket material I noticed that Honda made a couple of different lengths of the camshaft (drivers side) bearing (holder).
Causing some bearing ends to bind the camshaft when the gasket is to thin. That said, I have also noticed that some of the shorter bearings looked as if they were filed which may also be warn, which applies to both ends. I would look at the gasket width first and see if the tach drive gear and bolt are causing excessive wear on the gear/housing. Also, that much movement can cause side wear on the cam chain.
B ill
B ill
> lyletrudell
> Saturday, March 12, 2011 2:32 PM
> [anzhonda600owners] Re:
> Yours looks
> little, allowing more end movement. Not sure how the sedan cam holder > looks.
> If I remember correct the camshaft end controls movement on the tach > side, not the gear. On the distibutor side the 3rd diameter (largest) controls > movement. Probably could shim the cam holders or use thinner gaskets.
> See
> good!
> Lyle
> > I thought I would
> go through my Coupe a bit and check gaps and such. I started with the points > gap. I set it to .35mm as it seemed a bit small, though I couldn't detect a > problem while driving it. My concern now is this: I ran the car a bit with the > cover off "just to see" and noticed that the end of the camshaft floats in and > out. Please look at the video; is this excessive? Note that I have a sedan > engine in the car; maybe the tach setup at the other end would prevent the > movement to some extent.
> > Thanks,
> > Steve
Hi Bill,
Not sure which gaskets you are reffering to.
Also, as I mentioned my coupe has a sedan motor in it - no tach setup. I took a look at everything again, and played around with some spare parts I have, to try to get a sense of how the parts interact. After pondering all that I made a little webpage that shows what I understand of all of this so far...I will add to it as this gets worked out.
http://www.honda600coupe.com/floating_points_lobes/
Steve;
The thickness of the gasket (thicker) will pull the cam holder away from the cam lobe closest to it. A thinner gasket will make it closer. Your cam seems to have to much room between the inside edge of the Cam holder end the the cam. Leaving it room to move back and forth.
> Steven
> Michelsen
> Sunday, March 13, 2011 5:14 PM
> 2cylinderhondas@yahoogroups.com;
> Hi Bill,
> to. Also, as I mentioned my coupe has a sedan motor in it - no tach > setup. I took a look at everything again, and played around with some > spare parts I have, to try to get a sense of how the parts interact.
> After pondering all that I made a little webpage that shows what I understand > of all of this so far...I will add to it as this gets worked > out.
> Steve
> > billmyong@...
> > 2cylinderhondas@Yahoogroups.
> > Com
> > Sunday, March 13, 2011 6:58
> > AM
> > [2cylinderhondas] RE:
> > [anzhonda600owners] Re: points and camshafts
> > Steve;
> > When I was looking for the correct width of gasket material I > > noticed that Honda made a couple of different lengths of the camshaft > > (drivers side) bearing (holder). Causing some bearing ends to > > bind the camshaft when the gasket is to thin. That said, I have also > > noticed that some of the shorter bearings looked as if they were filed which > > may also be warn, which applies to both ends. I would look at the > > gasket width first and see if the tach drive gear and bolt are causing > > excessive wear on the gear/housing. Also, that much movement can cause > > side wear on the cam chain.
> > B
> > ill
> > > On Behalf Of
> > > lyletrudell
> > > Sent:
> > > PM
> > > camshafts
> > > Yours
> > > holders a little, allowing more end movement. Not sure how the sedan cam > > > holder looks.
> > > If I remember correct the camshaft end controls movement > > > on the tach side, not the gear. On the distibutor side the 3rd diameter > > > (largest) controls movement. Probably could shim the cam holders or use > > > thinner gaskets.
> > > Hey it sounds like
> > > it's running good!
> > > Lyle
> > > > I thought I
> > > would go through my Coupe a bit and check gaps and such. I started with > > > the points gap. I set it to .35mm as it seemed a bit small, though I > > > couldn't detect a problem while driving it. My concern now is this: I ran > > > the car a bit with the cover off "just to see" and noticed that the end of > > > the camshaft floats in and out. Please look at the video; is this > > > excessive? Note that I have a sedan engine in the car; maybe the tach > > > setup at the other end would prevent the movement to some extent.
> > > > Thanks,
> > > > Steve
Hi Steve, I just looked at my supply of engine parts. I have a Sedan head and it's the same except for the cam holder on the drivers side.
But this doesn't matter, they both do the same thing.
I put a cam holder from my coupe with the tach drive and it bolted right up!
This is how the cam is located for end play:
*The 2 cam lobes closest to the ends of the cam shaft have a machined surface. This is a controlled distance from the factory, I measured 3 cams and they check from finished surfaces (7.473"-7.477").
*The cam holders are a combination bearing surface and they also control end play. When installed with the proper gasket thickness, the distance should be (.004"-.014") greater than the cam length. This is why the gasket thickness is so important.
Other things to look for:
* Worn or damaged cam holders.
* Damaged surface on the head that the cam holders bolt up to.
* Worn cam or surface re-machined undersize.
, wrote:
> Steve;
]On Behalf Of Steven Michelsen
> Sent: Sunday, March 13, 2011 5:14 PM
> Subject: [anzhonda600owners] Re: points and camshafts
> Hi Bill,
> Not sure which gaskets you are reffering to. Also, as I mentioned my
> Steve
> From: billmyong@...
> To: 2cylinderhondas@Yahoogroups. Com ;
> Sent: Sunday, March 13, 2011 6:58 AM
> Subject: [2cylinderhondas] RE: [anzhonda600owners] Re: points and
> camshafts
> Steve;
> different lengths of the camshaft (drivers side) bearing (holder). Causing
]On Behalf Of lyletrudell
> Sent: Saturday, March 12, 2011 2:32 PM
> gaskets.
> Lyle
, Steven Michelsen
> > Thanks,
> > Steve
Hi Lyle,
Thanks for that. I measured the cam-holder-to-cam gap at .023 inches. A bit over but not horrible I suppose; about half a millimeter as I guessed. What I don't get it that the points lobes seemed to drift quite a bit more than that. I ought to run the test again and somehow cram a ruler in there. Hopefully it's much ado about nothing; I was just surprised by the motion you can see in the video.
> lyletrudell
> Monday, March 14, 2011 12:47
> and camshafts
> Hi Steve, I just looked at my supply of engine parts. I have a Sedan head > and it's the same except for the cam holder on the drivers side.
> But this
> have a machined surface. This is a controlled distance from the factory, I > measured 3 cams and they check from finished surfaces > (7.473"-7.477").
> they also control end play. When installed with the proper gasket thickness, > the distance should be (.004"-.014") greater than the cam length. This is why > the gasket thickness is so important.
> holders bolt up to.
> undersize.
> Lyle
> > Steve;
> > The
> the cam lobe closest to it. A thinner gasket will make it closer. Your > cam > > seems to have to much room between the inside edge of the Cam > holder end > > the the cam. Leaving it room to move back and > forth.
> > -----Original
> Message-----
> ]On
> > Hi Bill,
> > again, and played
> around with some spare parts I have, to try to get a sense > > of how the > parts interact. After pondering all that I made a little webpage > > that > shows what I understand of all of this so far...I will add to it as
> > Steve
> billmyong@...
> > camshafts
> > Steve;
> > look at the
> gasket width first and see if the tach drive gear and bolt are > > causing > excessive wear on the gear/housing. Also, that much movement can > > cause > side wear on the cam chain.
> ]On
> .014").
> > Probably the
> > end movement.
> > gaskets.
> > See what
> Lyle
> Steven Michelsen
> > > I
> > I
> started with the points gap. I set it to .35mm as it seemed a bit > small, > > though I couldn't detect a problem while driving it. My concern > now is this:
> > I ran the car a bit with the cover off "just to see" and > noticed that the > > end of the camshaft floats in and out. Please look at > the video; is this > > excessive? Note that I have a sedan engine in the > car; maybe the tach setup > > at the other end would prevent the movement > to some extent.
> > > Thanks,
> > > Steve
Hi Steve, I just checked my cam end play, something I forgot to check.
Removed the valve cover. Turned engine to TDC, so valve spring pressure would be light.
Used a screw driver between the cam gear and housing to move the cam all the way to contact the cam housing, light pressure! Then used a feeler gauge to check the gap on the other end. Mine checked (.009)
Not sure how you checked the gap.
Also remember to torque the cam holder bolts to spec.
Thinner gaskets would solve your problem.
> Hi Lyle,
> Steve
> From: lyletrudell
> Sent: Monday, March 14, 2011 12:47 PM
> Lyle
, wrote:
> > Steve;
> > [mailto:
> > Hi Bill,
> > Steve
> > From: billmyong@
> > camshafts
> > Steve;
> > [mailto:
> > gaskets.
> > Lyle
, Steven Michelsen
> > > Thanks,
> > > Steve
