Window regulator plastic slide
Post by lyletrudell »
Was working on my Orange coupe tonight. My doors are disassembled and ready for body work and primer.
Everything works good, but my regulator guide has plastic slides that are broken, common from what I have read.
I will make replacements.
The problem is the rivots are welded on!
So it either needs to be ground off or drilled out. Then a special shouler bolt or pin needs to be welded or bolted back together, not easy for some owners.
I was thinking about making a new guide that will work with no modifications needed.
If anyone is interested in a set, email me.
craft59@...
brad fenn
Re: Window regulator plastic slide
Post by brad fenn »
Lyle,I have fixed several of those,and I found the perfect part for it. I used some plastic door rollers that I got at Home Depot. They are rollers designed for sliding glass doors for your home.They came in a pack with a pin and e-clip. I took the regulator and punched out the peen-ed in pin with a drift and installed the roller with the new pin and e-clip. Now I had to turn down the plastic roller a little to make it fit the window track,but the pin fit snugly through the hole in the regulator(where the old peen-ed in pin was) and the e-clip fit on as if it was made for it. So if you can find the door rollers with pin that I found,You will be amazed how good it worked. I do have some new rollers still in the package if you need a part # . Just let me know.   Brad From:
lyletrudell To:
Thu, August 19, 2010 10:46:47 PM Subject:
[anzhonda600owners] Window regulator plastic slide
craft59@...
Hi Lyle;
I use the patio door rollers, they come with a bolt and by cutting them flat on two sides they slid just like the originals.  And at about $6.00 each set of two it is a cheap fix.
> lyletrudell
> Thursday, August 19, 2010 8:47
> Was working on my Orange coupe tonight. My doors are disassembled and ready > for body work and primer.
> I will make
> replacements.
> So it either
> needs to be ground off or drilled out. Then a special shouler bolt or pin > needs to be welded or bolted back together, not easy for some owners.
> I was
> thinking about making a new guide that will work with no modifications > needed.
> craft59@...
> Lyle
Brad, oops, didn't see your thread.   The great thing about it is that they work very well.  I even found some with ball bearings in them.
> brad
> fenn
> Thursday, August 19, 2010 9:26 PM
> Re: [anzhonda600owners]
> Lyle,I
> have fixed several of those,and I found the perfect part for it. I used some > plastic door rollers that I got at Home Depot. They are rollers designed for > sliding glass doors for your home.They came in a pack with a pin and e-clip. I > took the regulator and punched out the peen-ed in pin with a drift and > installed the roller with the new pin and e-clip. Now I had to turn down the > plastic roller a little to make it fit the window track,but the pin fit snugly > through the hole in the regulator(where the old peen-ed in pin was) and the > e-clip fit on as if it was made for it. So if you can find the door rollers > with pin that I found,You will be amazed how good it worked. I do have some > new rollers still in the package if you need a part # . Just let me > know.   Brad
> lyletrudell
> slide
> I will make
> replacements.
> So it either
> I was
> craft59@...
> Lyle
Hey, that sounds good. Will have to punch out one of the pins and see what I can find at Home Depot.
Brad if you can find the # for them that would be great.
I was going to make a 2 part, rectangle part with a hole in it.
Then just screw it together around the existing rivot.
But if your way works, then no reason to make something else.
Thanks
[mailto:
]On Behalf Of brad fenn
> Sent: Thursday, August 19, 2010 9:26 PM
> Subject: Re: [anzhonda600owners] Window regulator plastic slide
> From: lyletrudell
> Sent: Thu, August 19, 2010 10:46:47 PM
> Subject: [anzhonda600owners] Window regulator plastic slide
> craft59@...
> Lyle
brad fenn
Post by brad fenn »
The company that made the parts I used is "Prime-Line, the part# on the package is B-551, Its labeled "Window & Door replacement hardware" for sliding screen door. There are 2 rollers and pins. I was wrong about an e-clip,it has retainer screw.But as I said,it works great.
lyletrudell To:
Fri, August 20, 2010 11:51:12 AM Subject:
[anzhonda600owners] Re: Window regulator plastic slide
Thanks
[mailto:
> From: lyletrudell
> craft59@...
> Lyle
Thanks Brad, will head to Home Depot, need some stuff for the house also.
> From: lyletrudell
> Sent: Fri, August 20, 2010 11:51:12 AM
> Subject: [anzhonda600owners] Re: Window regulator plastic slide
> find at Home Depot.
> Thanks
> Lyle
> >[mailto:
> > From: lyletrudell
> >owners.
> >needed.
> > craft59@
> > Lyle
