center console
center console
does anyone have a n600 center console for sale or know where to find
one???
one???
Re: center console
i have one that i may be willing to part with. It is the complete console and shifter (yea the shifter is different for the console)
Sat, 9/13/08, fedweezee
> From: fedweezee
> Subject: [anzhonda600owners] center console
> Date: Saturday, September 13, 2008, 3:38 PM
> does anyone have a n600 center console for sale or know where to find > one???
carburator
My car doesn't like the choke. If I use it, after it's warmed up and I push it in it runs terrible so I don't use it. Without it, the car stalls all the time until I drive it several miles and it's a pain to coordinate the brake and gas to keep the rpms up to keep it running. Once it warms up it can idle nice and slow and runs great. However, when I drive it on the freeway and come to the exit, it will stall. What's the scoup?
Thu, 9/18/08, kris c
> From: kris c
> Subject: Re: [anzhonda600owners] center console
> Date: Thursday, September 18, 2008, 10:21 AM
> i have one that i may be willing to part with. It is the complete console and shifter (yea the shifter is different for the console) > --- On > Sat, 9/13/08, fedweezee > > wrote:
> > From: fedweezee
> > To: anzhonda600owners@ yahoogroups. com
> > does anyone have a n600 center console for sale or know where to find > > one???
Re: carburator
Take a look at your carb.... you should see a linkage which goes between the choke cam and the throttle.
As you turn on the choke, you should see the throttle being opened for a faster idle speed.
Looking at your question....I don't quite understand your problem.
When it is warmed up you indicate it idles at the proper speed with the choke off....is this correct? When the engine is cold, as you pull out the choke, the idle speed should increase. Are you seeing the idle speed increase when you pull out the choke when the engine is cold? If not, check the linkage I mentioned above.
Check out WalletPop for the latest news and information, tips and calculators .
Looking for simple solutions to your real-life financial challenges?> My car
> doesn't like the choke. If I use it, after it's warmed up and I push it > in it runs terrible so I don't use it. Without it, the car stalls all > the time until I drive it several miles and it's a pain to coordinate the > brake and gas to keep the rpms up to keep it running. Once it warms up > it can idle nice and slow and runs great. However, when I drive it on > the freeway and come to the exit, it will stall. What's the > scoup?
Re: carburator
I'm probably the biggest dummy on this forum but for what it might be worth, that is pretty much the way mine acted until I finally got an idle solenoid replaced. Now it does good.
> goinhm@...
> Thursday, September 18, 2008 5:11
> carburator
> Take a look at your carb.... you should see a linkage which goes between > the choke cam and the throttle.
> As you turn on the choke, you should see the throttle being opened > for a faster idle speed.
> Looking at your question.... I don't quite understand your > problem. When it is warmed up you indicate it idles at the proper speed > with the choke off....is this correct? When the engine is cold, as > you pull out the choke, the idle speed should increase. Are you > seeing the idle speed increase when you pull out the choke when the engine is > cold? If not, check the linkage I mentioned above.
> good luck,
> > My
> > car doesn't like the choke. If I use it, after it's warmed up and I > > push it in it runs terrible so I don't use it. Without it, the car > > stalls all the time until I drive it several miles and it's a pain to > > coordinate the brake and gas to keep the rpms up to keep it running.
> > Once it warms up it can idle nice and slow and runs great. However, > > when I drive it on the freeway and come to the exit, it will stall.
> > What's the scoup?
> Check out WalletPop for the latest news and information, tips > and calculators > .
> Checked by AVG -
> http://www.avg.com
> Version: 8.0.169 / Virus Database: 270.6.21/1672 -
> Release Date: 9/15/2008 9:21 AM
Kevin Lister
Re: carburator
idle solenoid?
--- On Thu, 9/18/08, cotton wrote:
> From: cotton Subject: Re: [anzhonda600owners] carburator
> Date: Thursday, September 18, 2008, 4:00 PM
> does good.
goinhm@...
> Sent: Thursday, September 18, 2008 5:11 PM
> your problem. When it is warmed up you indicate it idles at
> good luck,
> challenges? Check out WalletPop for the latest news and
> information, tips and calculators.
> Checked by AVG -
http://www.avg.com
Re: carburator
Can someone tell me where the best sources for parts for these cars are, pls? The dealer can special order an oil filter but not much more. I know about Ming. Anyone else? For example, if I needed the idle solinoid....
Fri, 9/19/08, Kevin Lister
> From: Kevin Lister
> Date: Friday, September 19, 2008, 3:54 PM
> idle solenoid?
> --- On Thu, 9/18/08, cotton cotteni@brazosnet. com
> > From: cotton cotteni@brazosnet. com
> > does good.
> goinhm@...
> > good luck,
> > Dale
> > Checked by AVG -
> http://www.avg. com
Re: carburator
Does anyone have a correct antenna for sale for the sedan?
> From: Kevin Lister
> idle solenoid?
> > does good.
> goinhm@...
> > good luck,
> > Dale
> > Checked by AVG -
> http://www.avg. com
Robert Goodrich
Re: carburator
the 600 shop in north or soth Carolina just google the honda 600 shop
Fri, 9/19/08, JN
> From: JN
> Date: Friday, September 19, 2008, 8:04 PM
> --- On
> > From: Kevin Lister
> > idle solenoid?
> > --- On Thu, 9/18/08, cotton > cotteni@brazosnet. com
> > > wrote:
> > > From: cotton > cotteni@brazosnet. com
> > > what it might be worth, that is pretty much the way mine > > > acted until I finally got an idle solenoid replaced. Now it > > > does good.
> > goinhm@...
> > > your problem. When it is warmed up you indicate it idles at > > > the proper speed with the choke off....is this correct?
> > > When the engine is cold, as you pull out the choke, the > > > idle speed should increase. Are you seeing the idle speed > > > increase when you pull out the choke when the engine is > > > cold? If not, check the linkage I mentioned above.
> > > good luck,
> > > Dale
> > after
> > > coordinate the brake and gas to keep the rpms up to keep it > > > running. Once it warms up it can idle nice and slow and > > > runs great. However, when I drive it on the freeway and > > > come to the exit, it will stall. What's the scoup?
> > > ------------ --------- --------- --------- --------- --------- - > > > Looking for simple solutions to your real-life financial > > > challenges? Check out WalletPop for the latest news and > > > information, tips and calculators.
> > > Checked by AVG -
> > http://www.avg. com
woodwizard
Re: carburator
Mike O'Conner, 600 Shop, located in Statesville NC
Wed, 9/24/08, Robert Goodrich
> From: Robert Goodrich
> Date: Wednesday, September 24, 2008, 7:51 PM
> the 600 shop in north or soth Carolina just google the honda 600 shop > --- On > Fri, 9/19/08, JN > > wrote:
> > From: JN
> > --- On
> > > From: Kevin Lister
> > > idle solenoid?
> > > --- On Thu, 9/18/08, cotton > > cotteni@brazosnet. com
> > > > wrote:
> > > > From: cotton > > cotteni@brazosnet. com
> > > > To:
> > > > I'm probably the biggest dummy on this forum but for > > > > what it might be worth, that is pretty much the way mine > > > > acted until I finally got an idle solenoid replaced. Now it > > > > does good.
> > > > From:
> > > goinhm@...
> > > > To:
> > > > Take a look at your carb.... you should see a linkage > > > > which goes between the choke cam and the throttle.
> > > > As you turn on the choke, you should see the throttle > > > > being opened for a faster idle speed.
> > > > Looking at your question.... I don't quite understand > > > > your problem. When it is warmed up you indicate it idles at > > > > the proper speed with the choke off....is this correct?
> > > > When the engine is cold, as you pull out the choke, the > > > > idle speed should increase. Are you seeing the idle speed > > > > increase when you pull out the choke when the engine is > > > > cold? If not, check the linkage I mentioned above.
> > > > good luck,
> > > > Dale
> > > after
> > > > it's warmed up and I push it in it runs terrible so I > > > > don't use it. Without it, the car stalls all the time > > > > until I drive it several miles and it's a pain to > > > > coordinate the brake and gas to keep the rpms up to keep it > > > > running. Once it warms up it can idle nice and slow and > > > > runs great. However, when I drive it on the freeway and > > > > come to the exit, it will stall. What's the scoup?
> > > > ------------ --------- --------- --------- --------- --------- - > > > > Looking for simple solutions to your real-life financial > > > > challenges? Check out WalletPop for the latest news and > > > > information, tips and calculators.
> > > > Checked by AVG -
> > > http://www.avg. com
