Restored Z Coupe for sale.
I haven't looked at this, but I saw another restoration these guys did at an auction back in 2016.
https://phoenix.craigslist.org/evl/cto/ ... -XXXX.html
The restoration looks nice. Some of the things I don't like are;
1. The negative ground to the engine is all wrong will be a source of problems. Look at the last photo and you will see the black negative cable going to the valve cover.
2. The rear end seems to be raised too much ...... what did they do to the rear suspension?
3. The rear window seems to have a lift arm added to keep it up.
4. The seat pockets on the driver side are incorrect .... they should be positioned between the seats so you can access them while you are in the car with the doors closed.
5. The seat upholstery pattern used is not the correct (minor item).
6. How much did they check out the engine? While it looks clean from the outside, does it have lots of old, tired parts on the inside?
While it looks nice, I think the asking price is too high. But I do hope there are people who are willing to give this person $22,000 for this car.
Happy motoring,
PS Once self-driving cars become established, the older cars are going to be banned from major highways. Better enjoy your old cars while you can.
Happy motoring,
> Chuck (mobile)
> Pleez x cuze enny tie ping or spelin air ores.
Re: Restored Z Coupe for sale.
The lift arm is only a chunk of pipe or wood. It doesnt look like it is attached to the rear window.
> On Mar 14, 2017, at 7:12 PM,
> goinhm@...
> 3. The rear window seems to have a lift arm added to keep it > up.
Chuck Dean
That's probably right, the one that they sold at the Russo and Steele auction back in 2016 had the same thing. Odd, they do such a good job restoring his cars but they can't get the springs right on the window?
On Mar 14, 2017, at 8:15 PM, J Graf
jgraf@...
> goinhm@...
Alan Stanyon
I agree rear hatch spring are tricky until you realize the workshop manual picture is incorrect or vague at best the piece of pipe lets the whole restoration down! other than that it's very nice.
Alan
2cylinderhondas@yahoogroups.com on behalf of Chuck Dean cadean329@... [2cylinderhondas]
15 March 2017 03:27
Re: [2cylinderhondas] Restored Z Coupe for sale.
Chuck (mobile)
Alan
15 March 2017 03:27
Chuck (mobile)
jgraf@...
> goinhm@...
It's a 1971 Coupe listed as a '72. They need the rear bumperette rubber strips, looks like seats are swapped L & R, the seat tilts go toward doors, maybe they had the car on a lift when rear shackles were tightened causing rear end raise, chrome on lug nuts mangled, has original hatch springs and a stick jammed in to assist hatch - possibly the pawls are damaged, radio knob busted off, wrong cigarette lighter, carpets bunched up and wrong material, dash vent speaker warped, wonder what's under steering wheel wrap?, no battery hold down, odd grounding methods, horn should be black, missing long front engine bolt and has cooling fan bolts in cam housing where 55mm flange bolts should be. Braided hose on engine breather where black difficult to get thinwall tubing should be. The use of the word restored should be ignored and possibly repaired or refurbished and the person writing the ad has some real spelling issues. Other than that body looks great!
Ken Christerson
Does this make my half restored version worth $11,000?
On Tue, 3/14/17, Chuck Dean
cadean329@...
Subject: [2cylinderhondas] Restored Z Coupe for sale.
To: "Honda 600 Group" <
Date: Tuesday, March 14, 2017, 11:25 AM
2016.
https://phoenix.craigslist.org/evl/cto/ ... html%c2%a0
Chuck (mobile)Pleez x cuze enny
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXX --
#yivXXX-XXX-XXXXygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px
0;padding:0 10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp hr {
border:1px solid #d8d8d8;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXhd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXads {
margin-bottom:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad {
padding:0 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad p {
margin:0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad a {
color:#0000ff;text-decoration:none;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor
#yivXXX-XXX-XXXXygrp-lc {
font-family:Arial;}
#yivXXX-XXX-XXXXygrp-lc #yivXXX-XXX-XXXXhd {
margin:10px
0px;font-weight:700;font-size:78%;line-height:122%;}
#yivXXX-XXX-XXXXygrp-lc .yivXXX-XXX-XXXXad {
margin-bottom:10px;padding:0 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span {
font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span:first-child {
text-transform:uppercase;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span a {
color:#5085b6;text-decoration:none;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span span {
color:#ff7900;}
.yivXXX-XXX-XXXXunderline {
text-decoration:underline;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
0;width:400px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach div a {
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach img {
border:none;padding-right:5px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label {
display:block;margin-bottom:5px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label a {
#yivXXX-XXX-XXXX blockquote {
margin:0 0 0 4px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold {
font-family:Arial;font-size:13px;font-weight:700;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold a {
#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p a {
font-family:Verdana;font-weight:700;}
#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
span.yivXXX-XXX-XXXXyshortcuts {
margin-right:0;}
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table div div a {
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table {
width:400px;}
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXfile-title a, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:active, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:hover, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:visited {
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:active,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:hover,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:visited {
#yivXXX-XXX-XXXX div#yivXXX-XXX-XXXXygrp-mlmsg
#yivXXX-XXX-XXXXygrp-msg p a span.yivXXX-XXX-XXXXyshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXgreen {
color:#628c2a;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXMsoNormal {
margin:0 0 0 0;}
#yivXXX-XXX-XXXX o {
font-size:0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div {
float:left;width:72px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXreco-category {
font-size:77%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXreco-desc {
font-size:77%;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXreplbq {
margin:4px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean,
sans-serif;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg table {
font-size:inherit;font:100%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg select,
#yivXXX-XXX-XXXX input, #yivXXX-XXX-XXXX textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg pre, #yivXXX-XXX-XXXX
code {
font:115% monospace;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg * {
line-height:1.22em;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg #yivXXX-XXX-XXXXlogo {
padding-bottom:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-msg p a {
font-family:Verdana;}
p#yivXXX-XXX-XXXXattach-count span {
color:#1E66AE;font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco
#yivXXX-XXX-XXXXreco-head {
color:#ff7900;font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco {
margin-bottom:20px;padding:0px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXov
li a {
font-size:130%;text-decoration:none;}
li {
font-size:77%;list-style-type:square;padding:6px 0;}
ul {
margin:0;padding:0 0 0 8px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text {
font-family:Georgia;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text p {
margin:0 0 1em 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text tt {
font-size:120%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-vital ul li:last-child {
border-right:none !important;
#yivXXX-XXX-XXXX
Seriously Ken, it really depends on which half youve restored. Additionally, there is about a 20% better value if youve restored the front right quarter and the left rear. However, you lose significant value from the $11,000 if the half youve restored is made up of the front left and rear right quarters.
> On Mar 15, 2017, at 11:33 AM, Ken Christerson
> kchristerson@...
