Top End Noise
Top End Noise
Post by Miles »
You should check the rocker shafts. The ends get really worn. The
rockers get really worn where the cam runs on them, usually are dished
faily deep as well as the end that hits the valve stems. Don Laughton
was always amazed that the aluminum alloy housings didn't wear at the
point of contact with the rocker shafts, I would check there as well.
gary cushman
Re: Top End Noise
Post by gary cushman »
As soon as I get her un-locked, shes kinda froze up after 20 or so years not being turned over,once I get her to turn over Ill check the internals, thanks for the Info.
----- Original Message ---- From: Miles To: 2cylinderhondas@yahoogroups.com Sent: Friday, May 16, 2008 1:39:21 AM Subject: [2cylinderhondas] Top End Noise
You should check the rocker shafts. The ends get really worn. The rockers get really worn where the cam runs on them, usually are dished faily deep as well as the end that hits the valve stems. Don Laughton was always amazed that the aluminum alloy housings didn't wear at the point of contact with the rocker shafts, I would check there as well.
