Windshield rubber
Greg Hahs
Windshield rubber
Post by Greg Hahs »
I restore Isettas, and have found that the rubber for the windshields
and rear window are nearly a perfect match with the ones on the Honda.
Around $55.00 each including the locking strip.
Greg
riceburner006
Re: Windshield rubber
Post by riceburner006 »
--- In 2cylinderhondas@yahoogroups.com, "Greg Hahs"
>Hi Greg! Can you tell us anymore about this? I'm interested. How can I
get in touch with you? riceburner006
> Greg
Greg;
    The Isetta seal has a narrow inner lip wich makes it very hard to put into a Honda to the extent that windshields have been broken while trying to put them in.   And, the narrow inner lip can let go with a good bump.   There are a couple of seals that are close, but have you tried them?  After a couple of broken windshields I have gone to making my own.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Greg Hahs > Sent:
> Sunday, November 25, 2007 8:45
> [2cylinderhondas] Windshield rubber
> strip.
> Greg
Greg Hahs
Post by Greg Hahs »
You must have this seal confused with something else. The Isetta does
not have a narrow inner lip, (I've installed over a hundred) the ones
with those are designed to go onto the glass first and then sat in
the window opening with a cord in the outer channel that pulls
the "NARROW" section around the metal. The Isetta is exactly like the
Honda with a locking strip. It goes into the opening first and the
glass sat into the bottom channel and the rest pulled over the glass
with the curved tool. (real easy) Then the locking strip goes in with
the special locking strip installation tool that can be bought at any
auto parts store. The cross section of the Isetta seal is so close to
the cross section of the Honda that you can't measure the difference
with a set of calipers. These come with a locking strip for right
around $55.00. Come to think of it, I have never seen a locking strip
seal with a narrow inner lip, but that doesn't mean there aren't any.
Greg
, wrote:
> Greg;
to put
trying to
bump.
them? After
]On Behalf Of Greg Hahs
> Sent: Sunday, November 25, 2007 8:45 AM
> Subject: [2cylinderhondas] Windshield rubber
windshields
Honda.
> Greg
bruceb
Post by bruceb »
where do i find these seals? BMW dealer?  thanks, bruce
> -------------- Original message --------------
> From: "Greg Hahs"
> You must have this seal confused with something else. The Isetta does > not have a narrow inner lip, (I've installed over a hundred) the ones > with those are designed to go onto the glass first and then sat in > the window opening with a cord in the outer channel that pulls > the "NARROW" section around the metal. The Isetta is exactly like the > Honda with a locking strip. It goes into the opening first and the > glass sat into the bottom channel and the rest pulled over the glass > with the curved tool. (real easy) Then the locking strip goes in with > the special locking strip installation tool that can be bought at any > auto parts store. The cross section of the Isetta seal is so close to > the cross section of the Honda that you can't measure the difference > with a set of calipers. These come with a locking strip for right > around $55.00. Come to think of it, I have never seen a locking strip > seal with a narrow inner lip, but that > doesn't mean there aren't any.
> Greg
> , wrote:
> > Greg;
> > The Isetta seal has a narrow inner lip wich makes it very hard > to put > > into a Honda to the extent that windshields have been broken while > trying to > > put them in. And, the narrow inner lip can let go with a good > bump.
> > There are a couple of seals that are close, but have you tried > them? After > > a couple of broken windshields I have gone to making my own.
> > [mailto:
> > I restore Isettas, and have found that the rubber for the > windshields > > and rear window are nearly a perfect match with the ones on the > Honda.
> > Greg
Greg Hahs
Post by Greg Hahs »
Isettas-r-us
Werner Schwark he's in Georgia. isettas@... make sure you
ask for the correct length, they are cut short on the Isetta and you
need to make sure you get them longer.
Greg
> From: "Greg Hahs"
does
ones
the
glass
with
any
to
difference
strip
any.
> Greg
, wrote:
> > Greg;
> to put
while
> trying to
> bump.
> them? After
> > [mailto:
> windshields
> Honda.
> > Greg
Greg, youre still on the outside looking in.  I am talking about the width of the Honda 600 window frame.  You have not put one in, I can tell because your measuring without looking at the surface that rides against the frame.  The seal your talking about is nerrow on the inner side with inner lip moving downward as you  push the seal in.  Use your caliper on the honda 600 Sedan or Coupe, sure you can stress the rubber out by streching the thing all to bits.
> Monday, November 26, 2007 6:27
> [2cylinderhondas] Re: Windshield rubber
> Isetta does
> not have a narrow inner lip, (I've installed over a hundred) > the ones > with those are designed to go onto the glass first and then sat > in > the window opening with a cord in the outer channel that pulls > the > "NARROW" section around the metal. The Isetta is exactly like the > Honda > with a locking strip. It goes into the opening first and the > glass sat > into the bottom channel and the rest pulled over the glass > with the curved > tool. (real easy) Then the locking strip goes in with > the special locking > strip installation tool that can be bought at any > auto parts store. The > cross section of the Isetta seal is so close to > the cross section of the > Honda that you can't measure the difference > with a set of calipers. These > come with a locking strip for right > around $55.00. Come to think of it, I > have never seen a locking strip > seal with a narrow inner lip, but that > doesn't mean there aren't any.
> Greg
> > Greg;
> > The Isetta
> to put
> > into a
> Honda to the extent that windshields have been broken while > trying > to > > put them in. And, the narrow inner lip can let go with a good
> bump.
> > There are a couple of seals that are close, but have you > tried > them? After > > a couple of broken windshields I have gone to > making my own.
> > -----Original
> Message-----
> ]On
> Behalf Of Greg Hahs
> > I
> windshields
> ones on the
> Honda.
> strip.
> > Greg
Greg;
    When was the last time you put an Isetta windshield seal in a Honda 600?  My problem with people that insist on making statements they can't back up, causing others to destroy original parts to what end I don't know is really puzzeling.  And, what is the $55.00 for the Isetta seal but make sure you purchase more so that you will have enough?  So it's not $55.00 for the seal, it's more because the seal for the Iseta rear window is much smaller than a Honda 600 rear window and even smaller yet for the Front windsheild.
    With this kind of lunacy it's a wonder we aren't using Ribbon Sealer from 3M.  You can pick up a box for about $40.00 bucks (Part number 08612).  Oh by the way, 3M stopped selling it to Just anyone because of the problems they were having with Do-It-yourselfer's.   Trying to make it do things it wasn't designed for.
    Greag, a great idea, but you have to try them out first.
> Monday, November 26, 2007 4:09
> Isettas-r-us
> isettas@bellsouth. net
> make sure
> you
> Greg
> thanks, bruce
> > ------------ -- Original message
> > From: "Greg Hahs"
> else. The Isetta
> does
> ones
> the
> glass
> with
> > the special
> any
> > auto
> parts store. The cross section of the Isetta seal is so close > to
> the cross section of the Honda that you can't measure the > difference
> strip
> > seal with a narrow inner lip, but that doesn't mean there > aren't > any.
> > Greg
> > > Greg;
> > > The
> Isetta seal has a narrow inner lip wich makes it very hard > > to > put > > > into a Honda to the extent that windshields have been broken
> while
> > trying to
> > bump.
> > them? After
> > > a
> > > Bill
> > > -----Original
> Message-----
> > [mailto:
> ]On
> Behalf Of Greg Hahs
> > windshields
> > Honda.
> the locking strip.
> > > Greg
> billmyong@...
> [mailto:billmyong@...]
> Tuesday, November 27, 2007
> 12:25 AM
> Anzhonda600owners;
> Cc:
> isettas@...
> RE: [2cylinderhondas] Re: Windshield
> rubber
> Greg;
> My problem with people that insist on making statements they can't back up, > causing others to destroy original parts to what end I don't know is really > puzzling.  And, what is the $55.00 for the Isetta seal but make sure you > purchase more so that you will have enough?  So it's not $55.00 for the > seal, it's more because the seal for the Iseta rear window is much smaller > than a Honda 600 rear window and even smaller yet for the Front > windshield.
> With this kind of lunacy it's a wonder we aren't using Ribbon Sealer from > 3M.  You can pick up a box for about $40.00 bucks (Part number > 08612).  Oh by the way, 3M stopped selling it to Just anyone because of > the problems they were having with Do-It-yourselfer's.   Trying to > make it do things it wasn't designed > for.
> Greg, a great idea, but you have to try them out first.
> > Isettas-r-us
> > make
> > sure you
> > ask for the correct length, they are cut short on the Isetta > > and you > > need to make sure you get them longer.
> > Greg
> > thanks, bruce
> > > From: "Greg Hahs"
> > > Bill
> > does
> > ones
> > > with those are
> > > the window
> > > the "NARROW"
> > section around the metal. The Isetta is exactly like > > the > > > Honda > > with a locking strip. It goes into the opening first and the > > > glass > > sat into the bottom channel and the rest pulled over the > > glass
> > with the curved tool. (real easy) Then the locking strip goes in > > with
> > any
> > > auto parts store. The cross section of the Isetta seal is > > so close > > to > > > the cross section of the Honda that you can't > > measure the > > difference > > > with a set of calipers. These come with > > a locking strip for right > > > around $55.00. Come to think of it, I > > have never seen a locking > > strip > > > seal with a narrow inner lip, > > but that doesn't mean there aren't > > any.
> > > Greg
> > > > Greg;
> > > > The
> > Isetta seal has a narrow inner lip wich makes it very hard > > > to > > put > > > > into a Honda to the extent that windshields have been > > broken > > while > > > trying to > > > > put them in. And, the > > narrow inner lip can let go with a good > > > bump.
> > > > There
> > are a couple of seals that are close, but have you tried > > > them?
> > After
> > > > a couple of broken windshields I have gone to making my > > own.
> > > > Bill
> > > > From:
> > > [mailto:
> > ]On
> > Behalf Of Greg Hahs
> > AM
> > > > To:
> > > windshields
> > > Honda.
> > > > Around $55.00 each
> > > > Greg
Greg Hahs
Post by Greg Hahs »
Yesterday!!!!! and the ones for the Isetta are $40.00. Thanks for
being such a nice guy and helping out others. And next time you feel
like insulting someone, why don't you do it it front of a mirror? If
this kicks me off the site for trying to help others in restoring
their Hondas in a cheaper way, so be it.
Greg
, wrote:
> Greg;
Honda 600?
back up,
is really
sure you
the
smaller
windsheild.
Sealer
08612).
problems
things it
> Sent: Monday, November 26, 2007 4:09 PM
> Subject: [2cylinderhondas] Re: Windshield rubber
> Isettas-r-us
you
> Greg
> > From: "Greg Hahs"
> does
> ones
in
like
> the
the
> glass
> with
at
> any
close
> to
> difference
right
> strip
> any.
> > Greg
, wrote:
> > > Greg;
> > to put
> while
> > trying to
> > bump.
> > them? After
> > > Bill
> > > [mailto:
> > windshields
the
> > Honda.
> > > Greg
