brakes
aloyshamirage
brakes
Post by aloyshamirage »
i have rebuilt my master cylinder , had it re sleeved but i still get
no pressure . what can i do , what have you done
yours truly ,
almost done
Re: brakes
Post by Steve »
Did your brakes work before you rebuilt the master cylinder? or was
it sitting for a long time? If sitting with no brakes, plan on
rebuilding the whole system. If it was just the master cylinder was
leaking then maybe you have the seals in backwards or bad check
valves or no fluid entering the master or?
jacket_jane
Re: brakes
Post by jacket_jane »
THANK YOU very much for such a speedy response . i am kind of new to this computer thing. i plan on getting the rear slaves from Mike Oconnor . Do you have any check valves?
  what about the lines, should i blow them out?is replacing the rubber with braided stainless really neccessary.
 p.s. it sat for 9 years and started (with starter fluid) after just cleaning the carb Miles Chappell wrote:
> Did your brakes work before you rebuilt the master cylinder? or was > it sitting for a long time? If sitting with no brakes, plan on > rebuilding the whole system. If it was just the master cylinder was > leaking then maybe you have the seals in backwards or bad check > valves or no fluid entering the master or?
> 2cylinderhondas@yahoogroups.com, "aloyshamirage"
> > i have rebuilt my master cylinder , had it re sleeved but i still > get > > no pressure . what can i do , what have you done > >                                         yours truly , > >                                                     almost done
Yahoo! Mail
Bring photos to life!
New PhotoMail
makes sharing a breeze.
