Check the brushes, they may be broken or nolonger making contact.
> deanbratcher1
> Wednesday, October 01, 2003 3:09
> Re: [anzhonda600owners] Re:
> [2cylinderhondas] charging
> thanks for the info,I'll check the ground
> tomorrow.But if i don't remember a ground coming off of the regulator.Also i > got a regulator at Autozone that they had listed for this car but it has a > different conection.Did they change the conections, or did autozone just have > the wrong part number.(i've got brake shoes and pads, and a fan belt there and > they were right but you never can tell) This all seemed to start when the fly > wheel came off last week, could that have damaged anything?
> Thanks for the help
> Dean
> > william colford
> > Wednesday, October 01, 2003 1:23
> > AM
> > Hi Dean;
> > Some times it's a
> > ground issue. look at the black wire going into the > > voltage > > regulator, and pull the plug apart and look for corrosion.
> > Then
> > look at the ground wire coming from the voltage regulator to the > > bolt.
> > Unscrew the bolt and clean the attaching surface. A Volt > > meter on the Ohm > > scale can check out the rectifier to see if it is acting > > like a diode should > > (only letting current travel one way. Check all > > the connections from the > > stator to the regulator. Pull them apart > > and clean them, then check for > > continuity. The Large Shop manual > > gives some very good tests.
> > Look around, you will be surprised at
> > what you will find just pulling
> > things
> > apart.
> > ----- Original Message
> > From: "wmdbratcher"
> > Sent: Tuesday, September 30, 2003
> > 11:12 AM
> > Subject: [2cylinderhondas] charging
> > I'm getting
> > nothing out of the generator. How should I go about
> > testing it.I'm pretty
> > sure the voltage regulator is fine.Also how do
> > you test the rectifier,
> > and what exactly does it do?
> > Thanks
> > Dean
> > To unsubscribe
> > from this group, send an email
> > to:
> > 2cylinderhondas-unsubscribe@yahoogroups.com
> > Your use
> > of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> > To
> > unsubscribe from this group, send an email
> > to:
> > anzhonda600owners-unsubscribe@yahoogroups.com
> > Your
> > use of Yahoo! Groups is subject to the
> > Yahoo! Terms of Service
> To
> to:
> Your
