theoretical redline
StangGuy67
theoretical redline
Post by StangGuy67 »
Since I don't have a tach on my N600, I wonder what the redline really is. I know there are lines on the speedo, but I can easily exceed them, especially in 4th gear. I find myself having to slow down while on the freeway, so I don't go too much over it.
How much over the 75 mph limit can I really go? Those of you with Z's, what is the rpm at 75 mph in 4th? I've done 80 and 85 before, even went close to 90, with a slight downhill. How bad is this for the engine?
Thanks-
Kraig Griffiths
72 N600
riceburner006
Re: theoretical redline
Post by riceburner006 »
> Thanks-
> Kraig Griffiths
> 72 N600
Very good Questions! I often wondered What RPM I was at in my
sedan. Do you have stock size tires? I'm not sure how accurate the
speedo is with 145x10 radials,as the sedan came with 5.20 bias tires
which are taller. You have a vary strong runner at 85-90 mph! Not
sure but I think I could pull 85 mph. I don't think it's too good
for an old worn crankshaft! When beating these motors the first
thing I noticed is piston slap,due to piston skirt/bore wear. You
know you have a fresh motor if its quiet. Maybe someone with a tach
can help us! riceburner006
Hi Kraig;
    The last time I was pulling those numbers I had a constant transmission speedometer gear in my full synchro trans.  75 will have your tac hitting above 6K, and 6K is redline.
> StangGuy67@...
> Monday, September 15, 2003 10:20
> [2cylinderhondas] theoretical
> redline
> the redline really is. I know there are lines on the speedo, but I can easily > exceed them, especially in 4th gear. I find myself having to slow down while > on the freeway, so I don't go too much over it.
> limit can I really go? Those of you with Z's, what is the rpm at 75 mph in > 4th? I've done 80 and 85 before, even went close to 90, with a slight > downhill. How bad is this for the engine?
> Thanks-
> Kraig
> Griffiths
> 72 N600
> To
> to:
> Your
> Yahoo! Terms of Service
