On Wed, May 8, 2013 at 9:30 PM, Elias Baldwin
> If it's cheap enough and you have the room, a complete yet rusty Z can make a good parts car ... for one that isn't rusted.
> I found my first 600 close to home as well, but it was completely rotten. I soon learned it was easier and cheaper to find a car that wasn't rusted and have it shipped (and they are out there) rather than try to fix a rotten mess that would probably never be right anyway. That said, I have been thankful many times to have a parts car, for reference if nothing else.
> On Wed, May 8, 2013 at 9:19 PM, T W S
> woofbiteme@...
> > DITTO,� double ditto!
> > Eric Geiger > egeiger@...
> > Wednesday, May 8, 2013 8:11 PM
> > Re: [anzhonda600owners] Re: New N600 Owner(hopefully)
> > stay away from rust. �you'll thank yourself later. �especially in the floors.�
> > On May 8, 2013, at 8:04 PM, Becky Flynn wrote:
> > > Well, the n600 didn't work out...but I found a z600 that looks pretty rough, although I think I can get it for at least $600. The only thing I'm worried about is it is going to need floor pans. I don't know if I should continue to save money and see if something better comes along, or go with it and pray the pans aren't that bad.
> > > On Fri, May 3, 2013 at 6:56 AM, richmccolman
> > > > > richmccolman@...
> > > wrote:
> > > > I agree with Eric and Chas:
> > > > Mike O'Connor is located in Statesville, NC, and he knows the 600 cars backwards and forwards. (Not too-too far from me, in fact -- I'm also located in NC.) > > > > Yes, the cam chain is definitely an issue with these little cars. The stock ones will last about 40,000 to 60,000 miles before they stretch and eventually jump the valve timing if not replaced. When that happens, the valves can get bent. But that problem can be taken care of during an engine rebuild. Some people replace the stock cam chains with heavier racing chain that should last a lot longer.
> > > > There's no telling exactly what shape the engine is in until a knowledgeable mechanic assesses it, and part of that assessment can't be done without opening up the engine and looking inside. It's always possible that someone mistreated it and did things like ran the engine with too little oil, causing much internal wear.
> > > > How mechanically savvy are
> > > > you, Becky? If you know a few things, you might be able to scope out stuff like whether the engine has bent valves, if you're interested. Regardless, much about the engine will be unknown until somebody looks inside it.
> > > > Is it a really good price you'd be getting it for? A full engine rebuild, or rebuilt replacement engine, could cost you a few thousand $$$ (~$3k, maybe), so you probably don't want to sink too much into the car if you'll have to also spend a nice chunk on the engine.
> > > > Brakes, in a car that's been sitting for that long, are probably not in very good shape, I'm guessing. Those will likely need a good bit of work too.
> > > > Do check up under the car and under floor mats, etc, for rusted places. Sounds like you're tuned into that issue already, but it's a good idea to check really closely. The readily-viewable parts of the body may look good, but the underside could be a different story. So look carefully.
> > > > Good luck with
> > > > it. I hope it'll work out for you to get and fix up the car!
> > > > Richard
> > > > --- In
> > > > mailto:anzhonda600owners%40yahoogroups.com
> > > > , Eric Geiger wrote:
> > > > > Depending on where you are in TN, mike oconnor may only be a few short hours away in NC. He's the east coast guy when it comes to 600s
> > > > > He also has a website honda600shop
> > > > > Eric J. Geiger
> > > > > PRG Nocturne
> > > > XXX-XXX-XXXX
> > > > phone
> > > > XXX-XXX-XXXX
> > > > fax
> > > > XXX-XXX-XXXX
> > > > mobile
> > > > > egeiger@... > > > egeiger@
http://www.prgnocturne.com/
> > > > > On May 1, 2013, at 11:51 AM, "Becky Flynn" > > > bfly1823@
> > > > ...>> wrote:
> > > > > I'm located more in the southeast. I live in TN. This car is pretty much my birthday present to myself. I adore little cars and the older they are the cooler they are to me. Needless to say if things don't work out with this car I'm going to be pretty bummed. Lol.
> > > > > On Wed, May 1, 2013 at 8:27 AM, Chas > > > chasgould@
> > > > ...>> wrote:
> > > > > Hi Rebekah,
> > > > > Welcome to the group and congratualtions on your N600 find. The major concerns with the engine are the camchain, which should be tended to as a preventative measure as these tend to fail on cars that have sat for a long time. It is not a huge job but should be done before damage occurs. Where are you in the East. I am in Newton (near Boston) Massachusetts, and I would be happy to show you our Honda Z cars and let you drive one to get a feel for the car. If it is close enough, i would be happy to check out your prospective purchase for you as well. Also, I can give you some ideas of value so that you don't overpay for this car, especially if it has not run since 1993.
> > > > > I think that it is
> > > > wonderful that you are interested in these cars, and you will have a blast with this car.
> > > > > Chas
> > > > > --- In
> > > > >, "azhonda72" wrote:
> > > > > > My name is Rebekah and I have been searching for a long time to find a n600 on the east coast near me that isn't a complete rust bucket. Lucky for me I've found two! One is a little over priced but the other seems to be in ok shape. I was wondering what were some things I should look out for before I go buy it? It needs a passenger side window and looks like it might need a door as well. Basically, I want to be able to go look at this car and make a well informed decision. Any help is > > > > greatly appreciated.
